Nexus NX4203S120 -- Has anyone seen one of these?
  • aaronwt6
    • Apr 2013
    • 855
    • US
    I have a chance to pick one of these up tomorrow for $30. Turns on but has no sound or picture. Problem is I see very little in the way of parts for it. Seems that the 240Hz version is a little more common but I'm worried about finding what I need once I have it in hand. I thought I'd ask first and see if maybe some other brands use the same parts.
    Thanks in advance!
    http://www.rakuten.com/prod/nexus-nx...211822499.html
  • capkid
    • Oct 2010
    • 1339
    Re: Nexus NX4203S120 -- Has anyone seen one of these?
    I figure you've probably moved on from this TV by now. Anyway, I worked on a Nexus awhile back, but it was a 2006 model. The TV had a "sound, but no picture" issue. The internals were mainly LG, and I just had to change out the IPMs.
    LG Plasma Mal-Discharge Correction Service
    • aaronwt6
      • Apr 2013
      • 855
      • US
      I actually picked it up but haven't opened it yet to take a look. It's an LCD and the screen is scraped up pretty good. I may just part it out if I can figure out what's wrong first. I'll post an update this weekend once I get the back removed.
      Thanks!
      • Caleb
        Smokin IC's
        • Feb 2013
        • 645
        Ive got a 50" nexus plasma I havent been able to find any parts for, mine uses an obscure power supply but as I recall the y and x were lg.
        Liberating magic smoke one part at a time
        • capkid
          • Oct 2010
          • 1339
          Yeah, I believe the PSU in the 42" Nexus plasma I repaired was Chinese, and I'd never heard of the manufacturer.
          • gabri2211
            Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
            by gabri2211
            Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
            This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
            This NEXUS connector broke.
            Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
            The Xbox has a power supply that provides 12 volts on all outputs, so the power...
            07-28-2025, 07:13 PM
          • Popalwali
            Asus Nexus 7 2012 (ME370T REV 2.4) Schematics needed
            by Popalwali
            Hello Everyone,
            I will be really grateful if someone shares schematics and if possible the boardview of the old Asus Nexus 7 (2012) Tablet. The motherboard is ME370T Rev. 2.4. Now I can find schematics for the Rev. 1.0 but I could not find the schematics for the Rev 2.4. I tried to look for similarities in the Rev. 1 but there are somethings missing, plus the board i have has nearly no component names printed on it which as a newbie makes pretty hard for me to locate things. Any assistance will be appreciated. Thank you.
            08-25-2024, 11:28 AM
          • vladimir1909
            BIOS SHARE NEXUS MLK_Alienware X16 R2_LA-M41AP R10
            by vladimir1909
            Bios backup...
            11-25-2024, 12:49 PM
          • audiomodder
            Nexus 5 BATT_ID issue
            by audiomodder
            Hey folks,
            I have a used Nexus 5 motherboard I bought with a ripped out battery connector. Replaced the connector but phone won't start unless VBATT_THERM is disconnected. Then it seems to work fine but of course only shows 0% charge. Did factory reset and it does detect the charger.
            I've tried 3x batteries and they all measure ~68Kohms to ground on that pin.
            To make matters weirder, BATT_ID is grounded on the battery itself, I cannot understand why they even bothered with it connecting to the MCU. VBATT_THERM (i.e. VBAT_THRM) also connects to the MCU.
            04-24-2018, 10:55 AM
          • tehmatix
            Asus XG17AHP portable monitor
            by tehmatix
            I have this problem : replaced display B173HAN05.0 HW3A with B173HAN05.0 HW4A and the monitor doesn't run on 240Hz. Connected to laptop it's show 240hz on settings but setup on that refresh rate the screen is flickering black. If I choose 144Hz is running ok.
            With the original display, B173HAN05.0 HW3A, smashed, I don't have any issue.
            11-16-2022, 04:27 AM
