Nexus 5 BATT_ID issue
  • audiomodder
    • Dec 2017
    • 54
    Hey folks,
    I have a used Nexus 5 motherboard I bought with a ripped out battery connector. Replaced the connector but phone won't start unless VBATT_THERM is disconnected. Then it seems to work fine but of course only shows 0% charge. Did factory reset and it does detect the charger.
    I've tried 3x batteries and they all measure ~68Kohms to ground on that pin.
    To make matters weirder, BATT_ID is grounded on the battery itself, I cannot understand why they even bothered with it connecting to the MCU. VBATT_THERM (i.e. VBAT_THRM) also connects to the MCU.
    Schematics (page 223): https://mega.co.nz/#!AoY2gKbA!5fTTr1...p6Od5GPNdUL7Rw
    Thanks for any help!
  • audiomodder
    • Dec 2017
    • 54
    Re: Nexus 5 BATT_ID issue
    traced everything out and I think it must be the GPIO pins on the MCU. cant fix it without painful BGA work :/
    • rounin
      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
      by rounin
      🛠 Original Issue
      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
      04-19-2025, 01:18 AM
    • ugamazing
      by ugamazing
      12-17-2024, 07:05 PM
    • shahnld
      Lenovo legion 5 pro startup issue
      by shahnld
      Good day Experts
      I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
      A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
      And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
      08-24-2025, 12:31 PM
    • ahmarzo
      Acer laptop battery draining issue
      by ahmarzo
      Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
      Help me to diagnose this issue as there is no shortage in the inputs MOSFET
      08-02-2025, 06:39 AM
    • elmark
      HP 15-cw1002ua strange keyboard issue
      by elmark
      HP Pavilion 15-CW1002UA
      S/N 5CD0251CBC
      P/N 7KE54EA
      Hello guys!
      I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
      It powers on OK and has no other issues except the following:
      • CAPS LOCK does not work at all
      • Fn button toggles Flight Mode
      • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
      • (with SHIFT pressed: 't%' and 'y^' respectively)
      I initially thought it was a keyboard malfunction (internal short, etc.),
      but when I press and hold...
      06-27-2025, 01:10 AM
