55" Vizio XVT553SV no power, just orange standby after power surge
  • mitsu2k
    • Aug 2013
    • 199
    Hello gentlemen!! I'm working on a Vizio XVT553SV tv. What happened is there was a power surge in the home electrical lines that took place with the tv off. However, the tv no longer turns on. The orange Vizio Standby logo lights up orange and never turns to white when the power button is pressed nor does the tv have any audio or video. I did notice however that when the power button is pressed, the standby led goes from bright to dim orange several times. I currently have the back cover off the tv. I have checked the main fuse on the power board as well as all the small fuses on the mainboard and all were good. I am very comfortable working on boards and soldering but I am at a loss for where to start in diagnosing the problem here. Not sure if the problem lies with the power board or with the mainboard. I would greatly appreciate if you guys could help me along with this.
    Thank you!!
    Re: 55" Vizio XVT553SV no power, just orange standby after power surge
    This is most likely a bad main board on these models. If you post some pictures of inside the unit, it may be possible to rule out the other parts so you know it is the main board at fault.
    • mitsu2k
      • Aug 2013
      • 199
      Hello Tom, Thank you for your help. The requested photo is attached.
        OK, left hand yellow board is your power board.
        Right hand green board (with video inputs) is the main board.
        On the power board there is a power cable which connects to the main board. Can you get a closer shot of around that cable?
        • mitsu2k
          • Aug 2013
          • 199
          Hi Tom, these pics may not be clear enough but let me know if I need to take better ones. Thanks!
          I found someone has some good pics here: https://www.badcaps.net/forum/showth...light=XVT553SV
          The TV is at my friend's house so I am unable to take new pics at the moment but hopefully the ones I have and the pics from other thread will help.
          • mitsu2k
            • Aug 2013
            • 199
            Any ideas?
            • aaronwt6
              • Apr 2013
              • 855
              • US
              I would say this is almost certainly a main board fault. Even if the power supply wasn't working, the Vizio light should turn white when the power button is pressed. The same 5V that runs the standby light also turns it white. I've had a few in this same state. The couple I did have with PS issues were at least outputting 5V and the logo would turn white even though nothing happened beyond that.
              • aaronwt6
                • Apr 2013
                • 855
                • US
                Seems these get damaged real easy from brief power outtages. Been the story on most of the Vizios I've picked up. Power goes out, TV never works again.
                • mitsu2k
                  • Aug 2013
                  • 199
                  Hi Aaron, that's what I sususpected. Do you think it's worth it to try and diagnose the fault on the mainboard or just replace it?
                  • aaronwt6
                    • Apr 2013
                    • 855
                    • US
                    Eeprom chip would be a likely suspect. You could check all the voltage regulators too. I've heard of people having luck with an eeprom swap but I tried two with no success.
                    • Ronkirsch
                      Nashville Ron
                      • Dec 2015
                      • 3
                      I've got the same problem with a Vizio XVT553SV. Power turns the logo orange but never white. Were you ever able to fix yours?
                      • fharris1977
                        Vizio D50u-D1 Dead Set No Standby
                        by fharris1977
                        Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                        12-28-2023, 10:25 AM
                      • p-top
                        Vizio, E60u-D3, no standby light, no ps_on
                        by p-top
                        Have vizio E60u-D3. No standby light. Have searched and read all D??u-D3 posts. posts with same symtoms fixed by new power supply, one guy needed back lights also.
                        main boards are kinda spendy and, out of stock alot of places. i would like to fix my board.
                        PS voltages
                        1 VSNS -2mV
                        2-5 LED-OUT -2mV
                        6-10 GND -2mV
                        11 +16VS 16.29V
                        12 AC-DET 3.929V
                        13PS-ON -3mV
                        14 +16VS 16.29V
                        15 +16VS 16.29V...
                        11-27-2023, 10:44 AM
                      • x_orange90_x
                        Vizio E550i-A0 no power, no standby light
                        by x_orange90_x
                        I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                        11-20-2023, 09:49 AM
                      • SS454
                        vizio e650i-a2 backlight flashes then turns off
                        by SS454
                        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                        panel: au optronics T650HVN05.4
                        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                        https://www.shopjimmy.com/vizio-56-0...-power-supply/
                        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                        08-20-2020, 03:57 PM
                      • tvguy12012012120
                        by tvguy12012012120
                        02-07-2025, 05:13 PM
