Sony KDL46z4100 Ribbon Cable
  • JBVeldkamp
    • Aug 2013
    • 22
    I posted on another forum, but just thought to check here in a new post.
    I have a KDL46z4100 that I botched the ribbon cable. This is the cable that goes from the TCON board to the LDC. Looking online I found a ribbon cable for the KDL46V4100, but none for the 46z. Should I be safe in getting this cable as the same?
    For reference, the part number for the one that I found is listed as YS0823.001781
    Thanks everyone!!
    Re: Sony KDL46z4100 Ribbon Cable
    If the part # is the same there should be no problem
    • JBVeldkamp
      • Aug 2013
      • 22
      Problem is there is no PN printed on the ribbon so I can't tell Do the manuals on your website have an extensive list of parts?
        A few do, but not all. ElektroTanya and servicemanuals.pro are other sites to check for service manuals.
        • JBVeldkamp
          • Aug 2013
          • 22
          OK, I'll go surfing again... Thanks Tom
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
          • zesko
            xps 9520 ribbon cable
            by zesko
            I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
            There is 2 models, idk which one is needed on my laptop.
            0xkvng
            00vpr2
            Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
            Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
            thanks...
            10-23-2025, 05:03 PM
          • lowpost99@gmail.com
            Need a replacement ribbon cable DELL Latitude E5470
            by lowpost99@gmail.com
            Anyone know if the ribbon cables are standard across laptops cases like in a PC, or are they proprietary to each manufacturer? I damaged the one that runs between the MB and the power / HDD / Battery Status Indicator LED Circuit Board. The Dell SKU/DPN: ADM70LED. I just need help finding a replacement. Could I possibly use a similar cable from a donor laptop?
            09-04-2024, 07:42 PM
          • NWArkGuy
            Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
            by NWArkGuy
            Well, I will be the first to admit that I screwed up...
            In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
            I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
            I have 2 that I have found and have in my possession. ...
            10-12-2023, 10:13 PM
          • alfredomfr1
            HP M32f FDH Monitor: 12v missing after connect the LVDS ribbon cable to the LCD circuit
            by alfredomfr1
            12v pin is shorted to ground in the LCD board (1st picture) if the LVDS cable is disconnected, 12v are OK in the Main Board (2nd Picture)
            06-04-2025, 10:23 AM
