Toshiba 37xv555db HDMI problem
+ More Options
Posts
  • WALTO TDI
    • Jul 2013
    • 21
    • uk
    Hi all I have just replaced the screen on a 37xv555db and also have a problem getting the sky box working on any HDMI input.
    Just purchased the tv so don't know the history.
    The DTV tuner works perfectly and so do the scart inputs.
    When selecting the hDMi input and having the sky box connected it just shows a blue screen. I have changed the plug to all three HDMI inputs but all three show a blue screen.
    Is there anything within the menu that I need to select or change so that I can get the sky box working?
    I have a spare main board and have changed it over and I still get the same blue screen.
    Any ideas appreciated!!
    Re: Toshiba 37xv555db HDMI problem
    Check your skybox is set to output 1080i/720p.
    • WALTO TDI
      • Jul 2013
      • 21
      • uk
      It's currently working on my samsung 720p so will the output on the sky box need to be changed to 1080 to work on the toshiba?
        It may be picky...
        If not, then it is probably a HDCP authentication problem. Someone has used the encryption keys for the Toshiba to copy some content (any Toshiba made in that year will likely use the same codes.) So Sky have seen it fit to block all users of that code.
        The only way to avoid this is to use a HDCP stripper like HDFury.
        • WALTO TDI
          • Jul 2013
          • 21
          • uk
          Where do I get hdfury from and how is it used?
            https://www.google.co.uk/search?q=hd...hrome&ie=UTF-8
            ... it's not particularly cheap.
            • spleenharvester
              Toshiba 50UL2063DB randomly rebooting with HDMI-CEC and/or HDMI-ARC enabled
              by spleenharvester
              I have this TV hooked up to only an AppleTV 4K and a Creative soundbar. Originally HDMI-CEC and HDMI-ARC wouldn't work at all, I replaced all the HDMI cables with decent UGREEN cables meeting the latest standards, now it all works perfectly but once or twice a day the TV itself reboots while watching a program, the AppleTV keeps running. I haven't fully pinned down whether it is ARC or CEC causing it yet. All are running latest firmware.
              I assume it is just HDMI-CEC being buggy as usual on a shitty Vestel machine, but can anyone think of anything I can try before disabling it?
              03-12-2025, 03:42 PM
              09-06-2024, 05:27 AM
            • delphi_firebird
              Toshiba Qosmio X755 Charging problem
              by delphi_firebird
              Hello Guys,
              I received Toshiba Qosmio X755 that has a charging problem and I'm stuck trying to figure out the problem.
              - When battery is unplugged i works without any problem.
              - When I plug in the battery after plugging in the charger, it works correctly and the battery is charging.
              - When I plug in the charger after inserting the battery, it stops working. ( voltage dropped and consumed 8A, reaching the maximum capacity of my bench power supply for 5 seconds, and stop working after )
              Can you help me diagnose the problem? I have attached...
              10-16-2023, 03:04 AM
            • budwich
              Sony Data Projector vplfh31 3LCD Blue missing
              by budwich
              Got this projector which has a problem with a lack of blue. Menu text is very yellow... expecting white. If I input a signal from a test disc via hdmi, a red screen image shows a uniform red as expect. Green similar while the blue does show but with non-uniformity. Looked at the in-polarizers. They are all good and clean. Running the projector to expose the light area in the prism block, shows each color well represented, all looking about the same intensity from the naked eye. Looking at the prism block itself and sending a light source back into the "out port", the individual...
              05-10-2024, 06:49 PM
              Toshiba Portege X30T Hybrid (2-in-1) Specification for Upgrade or Repair
              This specification for the Toshiba Portege X30T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X30T boardview and X30T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
              09-06-2024, 07:33 AM
