Re: 14 blinks TC-P50ST30
Northwestdad - Sorry for your issues as I'm having the same problem you are,, exactly.. Just wondering if you had any luck following up with moduslink.com as I'm having a hard time finding the SC board as well.. WIll probably give it a shot with repair kit they are selling if all else fails
tw2005 - see all of your feedback and everything has worked for but I can't seem to get any reading on multimeter from pins to ground to check the SD and SU boards.. Does that prove there isn't a short?
With the buffer boards if you have a meter measure these points.
SU board at connector SU41 , each of these pins 2,6,8 with respect to the gnd plate on buffer.
likewise, pin 6,2,1 SD42 to gnd plate on buffer.
disconnect the little white ribbon in between, disconnectd from the sc board also.
should be ok but to be sure.
Imagine if the tip spun and jumped out of the screw and onto the board, still spinning. Chance of breaking the copper tracks or taking out a surface component.
