14 blinks TC-P50ST30
  • tw2005
    • Oct 2011
    • 6458
    Re: 14 blinks TC-P50ST30
    Originally posted by macnbaish
    My crappy meter doesn't even have a continuity buzzer, but I ran down all the buffer ribbons with it set to 2000k and it never budged off of of scale high so that looks good to me. I see Shop Jimmy is out of the 5351AM replacement boards so I guess modus link is where to go next. I appreciate all the help, sorry for my brain farts there. Oh, and I'm now on the lookout for a nicer multimeter.
    hang on and I'll grab a board and see what resistance maybe ther, I hate cheap meters, just no good for exact work. Wrong decision here and we cook another Sc. yes i think repair/return, so many of these failed under wty from what I read even pansonic could not maintain supply
    • tw2005
      • Oct 2011
      • 6458
      we're looking at over 5 meg regardless of the way the probes are on my fluke. So this is well out of range for your meter, if it's OL or just shows 1, no reaction then I'd say they're good. I really don't know how your handles out of range. My meter goes to 30meg so it's never an issue for me
      In diode i get nothing one way and when reversed 0.7
      • macnbaish
        • Oct 2014
        • 12
        • US
        #143
        Yep, mine shows a 1 when it goes out of range, so I feel confident the buffer boards are ok. Picking out a new meter now for next time. I never realized how crappy mine was until this.
        A couple more questions for you if you don't mind. Like some other posters, my TV has no fans, although the back panel has vent holes that appear to be intended for fans to be mounted in there. I guess maybe they were cutting corners? Would it help extend the life of the unit to try to add some active cooling?
        Also, I was curious about newer firmware but the Panasonic support site doesn't even list my model, TC-P50S30. I see there is the very similar TC-P50ST30 that is on there and has updated firmware but I have no idea if they would be the same.
        • tw2005
          • Oct 2011
          • 6458
          Cooling will always extend a semiconductors life(should), can't help with mods but there's a few smart cookies who have with various models. yes i'd say being S30, that's entry level FHD and they do build them cheaper.
          I have no fans in my V20 and it's the high end non 3d fhd, I can say one transistor gets very hot and that's the one that's always shorted when mine goes and a bunch of other stuff.
          Don't think this is firmware related but more poor design.
          Either you're on a different site or your eyes are painted on(LOL)
          Don't use the ST30 firmware.
          I would only do this once the TV is running well and stable. If for some reason the SC failed whilst doing the upgrade the TV will be bricked being interrupted whilst it's writing to the EEPROM
          http://panasonic.jp/support/global/c...merica/na.html
          http://panasonic.jp/support/global/c.../down_na2.html
          • macnbaish
            • Oct 2014
            • 12
            • US
            #145
            Personally I think this is a conspiracy by Panasonic to make me look foolish lol. I went to the main site, clicked support, typed in "TC-P50S30". No results. Typed in "TC-P50ST30", came right up. It's funny, I even went to the "find your model" tool, and it suggested TC-P50S30 so I thought I finally had it, but as soon as I selected it it took me back to the results page - with no results still. Maybe it's because I'm getting the U.S. version of the site? Makes me wonder what the heck is going on. I bought it from Best Buy in the U.S.
            Anyway if I get it back working I'll take a look at the firmware. I'll consider slapping on some fans as well. Board is now removed and I'm hoping to ship it out today for repair.
            • macnbaish
              • Oct 2014
              • 12
              • US
              #146
              Forgot to mention - when I took the board off one of the mounting screws was very loose, barely touching the board at all I think. I'm guessing this may have been the cause of the failure. I'll be sure to check and tighten all screws when I put everything back together.
              • tw2005
                • Oct 2011
                • 6458
                got a picture of the screws used? I'm not 100% sure if this model has the issue but there are screw kits available, maybe washers are missing or incorrect lentgh? I'm not sure but I'd check it out , might as well while you're in there.
                • macnbaish
                  • Oct 2014
                  • 12
                  • US
                  #148
                  Picture of the screws are attached. The ones with the washers are only used where the su/sd boards are stacked on top of the sc board. All other sc board screws are the smaller ones with no separate washer, just a wide head.
                  • macnbaish
                    • Oct 2014
                    • 12
                    • US
                    #149
                    Got the repaired board and installed it and the TV powered right up. Working great! I made sure to tighten every screw on the back completely, and scraped away any buildup from the mount points. Thanks for all of your help!
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      #150
                      The screws are a known issue. In your picture above you can very clearly SEE where the board earthing has arced and made a black spot.
                      This black spot should be well polished off with some emery before refitting the repaired board or much the same will happen again.
                      TELEFIX
                      • darkTime
                        • Nov 2014
                        • 10
                        I hope there isn't a rule here about resurrecting old threads.
                        Anyway, I have read the entirety of this thread and I have a question.
                        I purchased a 14-blink TC-P46S30 for cheap.
                        I have a chance to buy a cracked screen TC-P50ST30 for cheap.
                        Based on the info in this thread I am fairly certain the error code on the 46 is due to a faulty SC board.
                        QUESTION: Can I use the SC board from the 50 in the 46???
                        Thanks for all the info, really interesting stuff
                        • northwestdad
                          • Feb 2014
                          • 51
                          • usa
                          #152
                          I would look at Shop Jimmy.com and see what compatability the SC board has. Type in the model number of your set and then search the results fo an sc board. I was able to get my repaired by ModusLink for under $50
                          • tw2005
                            • Oct 2011
                            • 6458
                            good chance it will, at a glance it's looking very close but you are assuming just because it has a cracked screen that the SC is still good unless of course it was cracked powered off and never powered on again. Quite often the buffers will short and blow with a cracked screen so also a possibility the Sc could also be bad.
                            just did a 50S30 and all that needed was 4 x 30f131 IGBTs replaced and it's been fine for a couple of weeks now but it can more involved.
                            how cheap is the ST30?
                            • darkTime
                              • Nov 2014
                              • 10
                              very cheap, like $40.
                              • Shelbyralph
                                • Oct 2017
                                • United states
                                #155
                                This is a way old thread but I am having the same issue. So far I have replaced the sd board, had the su board tested and was told it's good and had the sc board repaired but I still get the 14 blinks.I don't want to sink too much more in this thing but I hate to get rid of it. What is next step?
                                • FastEddie52
                                  • 18
                                  Also trying to revive old thread. I have a 2011 TC-P55ST30 that has the solid power led light that turns to blinking 14 when the power is pushed again. I have the service technical manual and have run through checking for shorts on Vsus, P15 and Vda with none found. When I removed the cable on SC2 the led blinks 7 times when I disconnected and SC2 and SC20 it blinked 8 times. The resistance across SC2 is multiple megs and also at TPSC1 and VF-5V. There are no shorts between the floating ground pads (screws removed) and SD42 and SU41 The boards were isolated from SC board and the ribbon cable connecting SC to SU was disconnected. The floating ground screws were tight when removed. I ran thru the decision tree for solid led failure on slide 61 of technical training manual, which led me to a bad A board because it was blinking 8 times instead of 6. Replaced A board with no change.
                                  So I believe it to be the SC board since that is the number 1 suspect but I do not show any shorts on the plugs. What is a more definitive test of the SC board?
                                  • N9ZN
                                    • Jul 2018
                                    Training Guide
                                    God bless you for posting that guide. I had it before I lost a hard drive on another PC and have been searching hi and low trying to locate it again. Now I can get down to business with my TC-P42ST30 that is in parts on my dining room table. That guide is the missing link I needed to get this 2011 plasma working again.
                                    Thank you so, so very much!
                                    Monty aka N9ZN (my amateur Xtra class license)
                                    • Andrew F. Ali
                                      • Jan 2014
                                      • 2450
                                      • Trinidad & Tobago
                                      #158
                                      Most of the time it is the SC Bd that goes bad wit the S and ST models from my experience.
                                      • aelb771
                                        • Aug 2018
                                        Sorry for bumping an old thread, but I have a TC-P55ST30 that had the 14 blink error. I used a meter to diagnose it and ended up ordering a used A board on eBay. I installed the board and the tv now turns on, but I am getting a very wide black band down the screen. I've checked and double checked all of the ribbon cables and don't see any issues. Do you think jay the a board I received may be faulty? Thanks in advance for the help.
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
                                        • Nairolf
                                          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                          by Nairolf
                                          I have a Samsung DM32D display.
                                          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                          Here’s what I have tried so far:
                                          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                          From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                          08-24-2025, 03:47 AM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          11-20-2024, 08:52 PM
                                        • Taurus12
                                          Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                                          by Taurus12
                                          Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                                          I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                                          i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                                          Any recommendation on what I have to do next? Thanks in advance
                                          06-10-2025, 05:05 PM
                                        • jchon
                                          Sony A1e 5-blinks help
                                          by jchon
                                          Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                          I found the service manual, which was critical to know where to probe.
                                          https://www.manualslib.com/manual/20...1e-Series.html
                                          With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                          Unfortunately the 5-blinks...
                                          06-28-2023, 11:52 AM
