So i have a couple of old 80's and 90's VCRs and they work good as RF modulators for a project im doing soon. But the VCR can only output on channel 3 and 4, is there any way to mod it to output on other channels like ch54?
VCR as RF Modulator
VCR as RF Modulator
I have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
Service Menu/Factory Reset Codes for TVs
http://www.badcaps.net/forum/showthread.php?t=24809Tags: None
by eccerr0rAnyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...-
Hi friends
I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about Β£15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board... -
by BOSCHNJAKABOUT ME INTRODUCTION FILE
2024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
2022 BEV, PROJECT ?
2021 BEV, PROJECT ?
2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIΔNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...-
Channel: Visitor Messages
12-28-2023, 02:09 PM -
by dicky96Hi Guys
I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
He also has an LG TV, so three screens in the bar
I installed three Satlink ST-6503 DVB-T Modulators
This model https://www.aliexpress.com/item/32916553905.html
These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to... -
by dicky96Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
Protection and Clip LED are off
There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...-
- Loading...
