Philips 42PFL7404 white screen
  • PowerAmpFreak
    • 977
    • Sweden
    Philips LCD model 42PFL7404 with just a white screen. Audio works.
    PSU voltages ok. T-CON fuse ok. What next?
    Re: Philips 42PFL7404 white screen
    What DC voltage do you get at the T-CON fuse? Pictures of the T-CON board?
    • PowerAmpFreak
      • 977
      • Sweden
      Hello budm, the T-CON recieve 11,85V measured on the fuse.
      Picture will come.
      • PowerAmpFreak
        • 977
        • Sweden
        Picture of the T-con attached
          At both ends of fuse?
          • PowerAmpFreak
            • 977
            • Sweden
            Oh yes!
              Look to be a few voltage regulators on there, tested those? Test the voltage across the few silver-purple radial capacitors too.
              • Daren87
                Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                by Daren87
                I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                08-13-2023, 03:25 PM
              • harp
                White screen repairs
                by harp
                To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                05-13-2024, 03:43 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • x_orange90_x
                TCL 50S535 bad tcon or panel issue?
                by x_orange90_x
                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                03-29-2025, 11:02 PM
              • alltvrepairs
                Lg TCon test pins for screen test
                by alltvrepairs
                i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                Appreciate your help....
                06-13-2025, 06:33 AM
