Panisonic 42inch TCP42S30 not working!!
  • Hok
    • Apr 2014
    • 70
    Re: Panisonic 42inch TCP42S30 not working!!
    i'm guessing the led on SN board is D583, and it does not light up. Tried to power up several times focusing on different sections of the board, never found a green led to light up
    • tw2005
      • Oct 2011
      • 6458
      I know I keep asking this but the panel itself, does it power up to give a normal display or just a flash or nothing at all, just a shutdown with SOS6?
      • tw2005
        • Oct 2011
        • 6458
        Yes D583
        • Hok
          • Apr 2014
          • 70
          the panel does not light up for long enough to give a normal display... It seems as though as soon as the screen flashes up it trips something and goes dark to SOS6. About 1 second or a little less.
          So it does get a full screen of gray/black with backlight before it goes into SOS mode
          • tw2005
            • Oct 2011
            • 6458
            Ok. I'm randomly trying stuff here so if it appears I have no idea, I don't! Can you set your meter to diode and place the probes across that D583 both polarities and also if you do it in low light watch carefully the D583 and tell me if there is a very faint green glow.
            I find when I probe these with my fluke it has just enough voltage to light it ever so dimly but is noticeable. It will be dim so bright light may be a hinderance.
            • Hok
              • Apr 2014
              • 70
              getting a short with both polarities on the led, can't get it to light up.... this mm may not provide enough voltage?
              • tw2005
                • Oct 2011
                • 6458
                Ok, in diode mode, what did the display read exactly what you see .
                • Hok
                  • Apr 2014
                  • 70
                  Diode mode reads 0L
                  • tw2005
                    • Oct 2011
                    • 6458
                    I might get you to repeat this on the same LED on the SS for comparison. Definitely should not be short. I would expect they'd go open if failed. Using my fluke on a SS it lights with a reading of 1.7
                    • tw2005
                      • Oct 2011
                      • 6458
                      Originally posted by Hok
                      Diode mode reads 0L
                      OL is out of range, out of limit. Try the SS and tell me what happens.
                      • Hok
                        • Apr 2014
                        • 70
                        i get the same reading (0L) on the SS board LED - D254
                        • Hok
                          • Apr 2014
                          • 70
                          ok SN board reads 0L but it DOES light up, sorry didn't see that a bit ago
                          • tw2005
                            • Oct 2011
                            • 6458
                            Disregard
                            • Hok
                              • Apr 2014
                              • 70
                              i found the problem
                              • tw2005
                                • Oct 2011
                                • 6458
                                So the part of the cct that feeds that LED is not producing voltage. I have had a board which was a 1 in a million had an open cct LED and that triggered SOS6.
                                The 5.6ohm resistors that feedthe DG302s, i forget we checked thos and were ok?
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  i found the problem
                                  Don't tease me like that, I'm getting frustrated, spit it out man
                                  • Hok
                                    • Apr 2014
                                    • 70
                                    I feel like a dolt. Went through for the THIRD time to check all the soldering that I did and found a poor connection on one of the DG302's. Resoldered and now the TV turns on gets a display etc.
                                    However, there are thin black horizontal lines across the display in several sections of the panel.
                                    If it isn't one thing, it's another.
                                    • Hok
                                      • Apr 2014
                                      • 70
                                      Can I swear on this forum? #%#@###! Panasonic!!!
                                      • Hok
                                        • Apr 2014
                                        • 70
                                        Here is an image of the display:
                                        • Hok
                                          • Apr 2014
                                          • 70
                                          Can't believe we've made it this far, and there is no way I would have been able to do this without badcaps and you, TW... and Glitcher, and Hombre for turning me on to those DG302's
                                          • MMH3
                                            Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                                            by MMH3
                                            i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                                            Never ever i experienced problems with that.
                                            Now i have one 5050sff machine, where this jumper isnt working at all.
                                            I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                                            The history of the machine is that i used it in my office...
                                            03-23-2025, 09:28 PM
                                          • DynaxSC
                                            GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                            by DynaxSC
                                            I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                            There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                            The board is generally working now, all PCIe ports are working, Windows installs normally.
                                            However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                            The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                            03-10-2025, 12:27 PM
                                          • obelix24
                                            Macbook Air 2020 (a2179) - touch id not working
                                            by obelix24
                                            Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
                                            I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
                                            02-09-2025, 12:57 PM
                                          • hopkok
                                            Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
                                            by hopkok
                                            Hi masters, I need your help.
                                            I am working on Lenovo Legion 16ITHg6
                                            Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
                                            INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
                                            My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
                                            AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
                                            Power LED is not working as well, power button working well.
                                            UI26 ??? is there any firmware too? Powered by +3VALW_AG.
                                            Motherboard...
                                            05-04-2025, 09:35 AM
                                          • bociub
                                            laptop freezes, usb 2.0 not working, usb 3.0 working
                                            by bociub
                                            Hi there,
                                            It is sunday and I got a faulty hp pavilion 15-cs1006na. No available schematics on the entire world. It flashed 5 long 4 short and no post then I discovered the usb 2.0 2. pin in one of the usb-a socket bent backwards and been shorted to 2. and 3. pin of the 3.0. after removing this short in the port the laptop came alive.
                                            Now the laptop freezing randomly. The webcam, the built in mic and according to the device manager one more thing not working which are connected to usb. If I connect anything what have usb 2.0 plug that wont work if i plug anything what...
                                            08-25-2024, 03:44 PM
