Replacing IC on inverter board
  • WALTO TDI
    • Jul 2013
    • 21
    • uk
    Hi all, can any one tell me how easy it is to replace IC on inverter board on a toshiba 37xv555d. Is there any special kit needed or will a normal soldering iron do? And if I buy the inverter repair IC kit will the chips already be programmed?
    Re: Replacing IC on inverter board
    Any pictures? No program chips used for the inverter board.
    What is it not doing?
    • WALTO TDI
      • Jul 2013
      • 21
      • uk
      The capacitors leaked and it has blown a leg on the IC chip
      So I was going to buy the repair kit off eBay and try to replace. I have already replaced the caps but then I noticed this damage on the IC
      • WALTO TDI
        • Jul 2013
        • 21
        • uk
        Does anybody know How easy it is to change this chip then?
        Cheers
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Pictures? Part number written on the chip? ... We need more info to be able to help you!...
          Muh-soggy-knee
          • notallbad
            • Oct 2012
            • 1190
            Help us to help you!!!
            Add photos of the board (both sides), details of the TV and the board(s) and identify the parts in question by component type and part numbers if possible or indicate where on the board they are in relation to other known parts or by description.
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • Noodneek
              Replacing all the caps on the BenQ SW2700pt's power board didn't help...
              by Noodneek
              My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
              I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
              08-30-2024, 12:52 PM
            • lostone
              Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
              by lostone
              Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
              First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
              When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
              05-19-2024, 11:40 AM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
