LG 42PJ350-UB Sound, No Pic
  • adamp91gvm
    • Jan 2014
    • 706
    Re: LG 42PJ350-UB Sound, No Pic
    I have the same tv mines on and working but it goes off then comes back on after about 5 mins then does it more. More it is on
    • paulnetv
      • Mar 2014
      • 22
      • United Kingdom
      For the record, this one was a faulty ctrl board.
      • senndogg
        • Dec 2011
        • 383
        • Albania
        Hello!
        Another case of NO picture 42PJ350.
        Voltages:
        vs - 205v
        va - 60v
        vsc ~20v
        vzb - 117v
        -vy ~15V
        As Tom suggested in post 11 i disconnected the buffer board and saw only a slight decrease in voltages of vsc and -vy, but these remain still too low.
        I have minimal experience with plasmas and troubleshooting this is an enjoyable experience.
        I have the Ysus in my hand, where do i start?
        thanks in advance!
        • senndogg
          • Dec 2011
          • 383
          • Albania
          Today decided to go further. I am inspecting the place of interest, the smps of the Vy.
          Here are some pics. In the last pic i made a small debrief of the components an traces.
            Try checking the YPS FETs (or YPN FETs) if they are shorted the Vsc/-Vy can go down.
            • senndogg
              • Dec 2011
              • 383
              • Albania
              #26
              sorry for the noob question Tom, but which are the YPN/YPS Fets?
              At the moment I am suspecting sth. The voltage at the smps IC capacitor is fluctuating between 6-9 V. The other leg of the diode is steady 18V.
              • Lacio30
                • Mar 2015
                • United Kingdom
                #27
                Originally posted by tom66
                You need to unscrew the buffer boards completely, just have them connected to the orange ribbons and nothing else.
                Hello all,
                brand new to this forum and having exactly same problem as Nick1969 bellow. As there is no answer to his problem can you please let me know whether I should change Y-SUS board or just changing control board will fix it?
                I have same model TV and same reading as bellow. Help please
                08-25-2013 07:53 AM
                nick1969
                Vs = 204.6V
                Va = 60.6V
                Vsc = 23.5V
                Vy = 22.9V
                im guessing its Y sus board since VSC and Vy voltages are too low
                • stevey
                  • Nov 2016
                  • usa
                  #28
                  Same problem. After running the EXT AUTO GEN test I found the panel had a great picture. I was able to sub the main board and everything worked. Thanks everyone.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #29
                    Good work
                    • Nexxtron
                      • Jan 2016
                      • Bahamas
                      #30
                      Hello. I have the following voltages on a LG 42PJ350 TV
                      Vs = 205V
                      Va = 65
                      Vsc = 19V
                      Vzb = 114
                      I need some directions as to what to do next. Please note that the Vsc is only 19 volts.
                      Regards
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #31
                        Remove buffer retest vsc.
                        • Nexxtron
                          • Jan 2016
                          • Bahamas
                          #32
                          I completely removed the buffer board and tested Vsc and got 1.9V. When I replaced it, I got 19V again
                          • rapbalance
                            • Jun 2017
                            Originally posted by capkid
                            So, you can just repeat the tests performed earlier:
                            (1) Check the VS and VA voltages leaving the power supply.
                            (2) Check VSC and -Vy voltages on the Y-Sus then check Vzb on the Z-Sustain.
                            (3) If voltages are normal, place a jumper on the EXT_AUTO_GEN points on the logic board to see if test patterns show onscreen.
                            Edit: Let us know if you need more "how to" info.
                            My Vsc varies between 112 and 137V, and my Vy between 163 and 180V. Is this normal? Or is it faulty Y-board?
                            • PREDATOR1
                              • Oct 2016
                              • 5
                              • Romania
                              #34
                              Originally posted by nick1969
                              Hi
                              with the buffer ribbon cable unplugged VSC is 2.5v and Vy 1.9v
                              Hello guys!
                              Does anybody know where I should look further if VSC and Vy voltages are bad even with the buffer board disconnected from the Ysus?
                              I already replaced two 30j124 and two 30f124 IGBTs, as they were shorted and the power supply was entering in protection mode.
                              Thank you!
                              • PREDATOR1
                                • Oct 2016
                                • 5
                                • Romania
                                #35
                                No one?
                                • Unspun01
                                  • Jun 2011
                                  • 349
                                  Hi.
                                  What are the EXACT component locations of the parts that you replaced?
                                  IGBTs are gate controlled devices, You may have found the shorted IGBTs, but the low resistance gate drive resistors may have opened up when the IGBTs shorted out. The low-resistance resistors on the bottom of the board connected to the IGBT gate pin should be tested as well as the driver ICs, but first lets test the gate resistors.
                                  Visit shopjimmy:
                                  www.shopjimmy.com/lg-ebr66607501-ysus-board.htm
                                  Download the hi-resolution photos of the TOP and BOTTOM of the board, and highlight the components you replaced (in RED color) and upload them here for us to review.
                                  In fact, the shopjimmy board photo has the insulation foam still installed. It may be better to upload your own high-resolution photo with the foam removed to better see the traces and locations.
                                  • ChaosLegionnaire
                                    by ChaosLegionnaire
                                    09-13-2022, 09:02 AM
                                  • LEECH666
                                    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                    by LEECH666
                                    Good day ladies and gentleman!
                                    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                    01-19-2024, 05:46 PM
                                  • PlasMatt
                                    LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                                    by PlasMatt
                                    I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                                    09-20-2025, 06:50 PM
                                  • Christos Tsiligiannis
                                    Marian Trace Alpha sound card repair help
                                    by Christos Tsiligiannis
                                    Hello to the forum.
                                    My name is Christos, I am new to the forum here and i am posting from Greece.
                                    So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                    To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                    So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                    11-18-2024, 05:26 AM
                                    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                                    This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                    09-12-2024, 02:30 PM
