Bush LCD27TV006HD 2 secs to black
    Re: Bush LCD27TV006HD 2 secs to black
    Pin 1 of the OZ960GN should have a small capacitor attached to it. Put a bridge across this so it is shorted out. This should set the start timer to never expire. Run the set for a maximum of 30 seconds in this mode. Connect a computer and generate a full white frame, see if the panel is evenly lit. If not you have a bad bulb.
    • notallbad
      • Oct 2012
      • 1190
      OK tried that but still '2 secs to black'.
        Hmm, looks like they may have multiple protections. What do you measure on pin #3 of the OZ960GN?
        • notallbad
          • Oct 2012
          • 1190
          Pin 3 - ENA - 2.46v
            Working and not working? Same?
            • notallbad
              • Oct 2012
              • 1190
              In standby 0v, switch on 0v until lamps light then rises to 2.46v and stays constant even after lamps go out, can't leave it on for too long as still have the jumper across Pin 1 and GndA.
              Would a logic probe be of use here?
                Logic probe may be useful later, but at the moment a multimeter is more usable.
                Pin 2 and pin 7 readings please.
                I'm trying to figure out what is causing shut down.
                • notallbad
                  • Oct 2012
                  • 1190
                  Ok, just thought it worth mentioning that I had one if needed.
                  Pin 2 - OVP - 0v stby, quickly peaks to 0.9v, drops to 0v when lamps extinguish
                  Pin 7 - REF - 0v stby, 1.46v when lamps lit, drops to 0v when lamps extinguish
                    Hmm... REF should be 2.5V +/-10% please recheck otherwise the OZ960GN may be bad.
                    • notallbad
                      • Oct 2012
                      • 1190
                      Did check it a couple of times and it jumps quickly up to 1.46v briefly before dropping to 0v, hard to see an exact reading but its definately no more than 1.5v.
                      Well, 1.7v at the most with the DMM set to 2volt range. Never goes out of scale.
                      Checked a few more times and its reading different every time, 1.4, 1.3 1.9v.
                      Pin 5 - VDDA - 4.96v so the source voltage looks good
                        I would consider that as being a potential fault. That voltage determines the bulb voltage. If it is too low, the bulbs will strike (2 second period) but then go out because the voltage isn't high enough to sustain light.
                        • notallbad
                          • Oct 2012
                          • 1190
                          OK, so replacement board then, just wanted extra reassurance it wasn't the lamps.
                          Another Darfon board I have has an OZ960G, I wonder.
                            If it were an open bulb you'd see OVP hitting around 2~3V, though it's not impossible that you have a leaky-to-chassis wire or bulb causing this issue, just relatively unlikely given the REF voltage looks dodgy.
                            • notallbad
                              • Oct 2012
                              • 1190
                              Think I shall just get a replacement board, 20pins to unsolder and resolder, not likely to be easy for me and its possible the 0Z960 on my spare is shot too though it was a Mosfet blown on that one!
                              £3.42 for 2 from China, but with my soldering skills and the time it takes for carriage may as well buy a board, £9. Someone in UK but £9 for the I.C, huh.
                              • notallbad
                                • Oct 2012
                                • 1190
                                Board ordered.
                                • notallbad
                                  • Oct 2012
                                  • 1190
                                  Quick update.
                                  Still awaiting board, missed 1st delivery so waiting for re-delivery. Damn it!
                                  Anyway, got fed up and replaced the OZ960 with one from another spare board, one that was replaced due to a fault, so I know this board was faulty it had a blown mosfet unsure what else or what caused it but replacing the board fixed the tv.
                                  So, swapped the OZ960 and now get a screen showing something but its only lit up half of the screen, right side lit up, left side dim and the screen is flickering. Theres also some noise coming from the inverter board now, sounds like arcing could be poor solder joints where I removed the trannys to test and re-soldered.
                                  Bl-On - 4.1v
                                  OZ960G
                                  Pin 2 - OVP - 0.5v
                                  Pin 3 - ENA - 1.4v
                                  Pin 7 - REF - 1.4v
                                  Could be that this OZ960 is bad too!
                                  • notallbad
                                    • Oct 2012
                                    • 1190
                                    So thought the new board would solve all my problems, well that was not so!
                                    Back to the original fault with the replacement board.
                                    So I decided to check the 24v rails by removing inverter connectors and wiring up 2 12v bulbs in series, with them connected to Gnd and 24v from the PS b/d they do not light up, but if I connect them when the board is already powered up the lamps glow bright and steady as would be expected from a good 24v supply.
                                    So the question is: why are the lamps not lighting up when connected to PS before powering up?
                                      The cold resistance of the lamps can trigger the over current shutdown when the power supply is starting up from 0V. Take the resistance reading when lamps are cold, then you can calculate the in-rush current at start up.
                                      • notallbad
                                        • Oct 2012
                                        • 1190
                                        Resistance of both lamps in series is 5.6ohm, so a draw of 2.14 amps.
                                          Check again: 24V / 5.6 ohm = 4.3A
                                          A little high for a 27" LCD.
                                          • PNI E.
                                            Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                            by PNI E.
                                            Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                            03-17-2025, 04:23 AM
                                          • ttmi100x
                                            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                            by ttmi100x
                                            Greetings everyone,
                                            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                            Upon closer inspection...
                                            07-31-2024, 06:36 PM
                                          • cheeky2
                                            by cheeky2
                                            05-25-2024, 03:27 AM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
                                          • cmlewis89
                                            LG 47LB5DF blown power supply board
                                            by cmlewis89
                                            Hi folks,
                                            I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                            09-03-2024, 07:50 PM
