Bush LCD27TV006HD 2 secs to black
  • notallbad
    • Oct 2012
    • 1190
    Re: Bush LCD27TV006HD 2 secs to black
    Yes sorry, worked out based on 12v, getting confused with 12v bulbs and 24v rail.
    So that would explain test lamps not coming on at start up.
    • notallbad
      • Oct 2012
      • 1190
      To eliminate the ccfls and shorting to panel (wires, lamps) I have a spare panel but the connector to the bottom of the inverter board has two wires, black and white, whereas the original board only has one, black.
      Any ideas how best to connect up?
      • notallbad
        • Oct 2012
        • 1190
        Stripped panel, removed broken lcd, found 16 lamps, 8 lamps connect to one pin and 8 connect to the other. No circuitry just a connecting pcb board.
        So I can simply feed both wires into the one on the original inverter board to provide the return path.
        • notallbad
          • Oct 2012
          • 1190
          The 2 pins on the inverter are actually connected together so won't need to short the 2 wires together, just 'plug n play'.
          • notallbad
            • Oct 2012
            • 1190
            Does the same with spare panel lamps, half screen lit and flickers, admittedly these are 32" lamps driven from a 27" inverter. Same happens with just half the lamps connected.
            I am steering back towards the PS, caps????, the 2 main 400v caps have 314v and 316v, a little low I believe.
              Is 24V from power supply OK?
              • notallbad
                • Oct 2012
                • 1190
                Hi Tom
                Apologies for delay, yes there is a steady 24v present, would the BlOn only having 4.1v have a bearing here or is that sufficient?
                Thanks again
                  Shouldn't be an issue, unlikely to be PSU.
                  • notallbad
                    • Oct 2012
                    • 1190
                    I think the ccfl lamp test was sufficient to conclude they are fine and the fault resides on the inverter.
                    I have a couple of spare inverters so shall look at hooking them up to eliminate PS. Will need the PS wiring harness to the inverter to be re-wired.
                    • notallbad
                      • Oct 2012
                      • 1190
                      Guessing I just need to provide 24v and the BlOn for the inverter to fire up?
                        And DIM.
                        • notallbad
                          • Oct 2012
                          • 1190
                          ok thanks.
                          Once I have without question determined that it is in fact the inverter, not that I doubt you just want to prove for myself and gain experience doing so, I shall get back to troubleshooting the 2 'faulty' inverters, odd that both are faulty with the same fault but then could be a common fault with these and intend on finding it and repair both these boards. I've already spent more than I had hoped on this, inverter and remote, caps and don't really want to spend much more if it can be helped but as I'm gaining experience that eases the pain a little.
                          If I haven't already noted just for reference, I have powered up the tv with the T-Con disconnected and although the screen does not light up, as to be expected, I can see the lamps flickering still. Just thought I'd throw that in for elimination.
                          • notallbad
                            • Oct 2012
                            • 1190
                            What are VIPWM, VEPWM and VSel?
                            Which one is the Dim?
                            There is no voltage present on any of these at least not anything anywhere near even 1v.
                              I honestly have no idea if it is an inverter or CCFL fault, if I knew I would tell you. Connect both VIPWM and VEPWM to 5V with 1kohm resistor in series.
                              • notallbad
                                • Oct 2012
                                • 1190
                                Would that be on the inverter or PS side?
                                The PS b/d VE and VI PWM's appear to be connected to gnd, with the connector disconnected and DMM on 200ohm range get 0.4ohms(short test leads and get 0.4ohm) across VEPWM and gnd, VIPWM and gnd.
                                Just want to be sure what I'm doing here.
                                • notallbad
                                  • Oct 2012
                                  • 1190
                                  I now see where your going with this? The ve and vi are signals from the Main A/V b/d, and this will just bypass the PS b/d. I think!
                                  Shall let you know how it goes.
                                  • notallbad
                                    • Oct 2012
                                    • 1190
                                    So using a 1.2k ohm resistor from a 5v supply on the ps b/d then connecting the other end via 2 wires to ve and vi on the inverter b/d I still get the same fault. This gives 3.1v supply to ve and vi.
                                    • notallbad
                                      • Oct 2012
                                      • 1190
                                      With a spare inverter b/d and a spare panel with 32" lamps I connected up 5 of the 24v, 5 of the gnd, BlOn and VIPWM and the panel lit up with no issues.
                                      • notallbad
                                        • Oct 2012
                                        • 1190
                                        Next step I think is to hook up the spare inverter to drive the lamps on the tv in question and eliminate these for definate.
                                        • notallbad
                                          • Oct 2012
                                          • 1190
                                          Incidentally this spare inverter also has an OZ960 so shall note some observations for comparison.
                                          Unfortunately the spare inverter is for a 32" so will not physically fit the panel so shall either have to purchase another board or repair one of the faulty ones.
                                          • PNI E.
                                            Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                            by PNI E.
                                            Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                            03-17-2025, 04:23 AM
                                          • ttmi100x
                                            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                            by ttmi100x
                                            Greetings everyone,
                                            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                            Upon closer inspection...
                                            07-31-2024, 06:36 PM
                                          • cheeky2
                                            by cheeky2
                                            05-25-2024, 03:27 AM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
                                          • cmlewis89
                                            LG 47LB5DF blown power supply board
                                            by cmlewis89
                                            Hi folks,
                                            I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                            09-03-2024, 07:50 PM
