Panasonic TH-42PX80E
  • PowerAmpFreak
    • 982
    • Sweden
    Panasonic plasma, TH-42PX80E enters standby mode as soon as the powercord is connected to mains. A few relays click. Nothing further.
    Unable to get set enter operating mode by buttons. VA and VS never comes up.
    Is this a power problem or mainboard problem ??
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TH-42PX80E
    Not sure if it's PSU but your PSU could be similar design to this, I'd check those parts.
    From memory the fuses, wirewound resistor and Q406 can blow.
      You should get two clicks from relays, then a 20 second delay (or thereabouts) with one final click. If an error occurs during that or after that you'll get a blink code. Or does it just click on and freeze? If so I'd be thinking main board.
      • BigPete
        Panasonic Heatpump Dryer Repair
        by BigPete
        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
        Unfortunately the whole machine has to come apart to fix it.
        I have...
        11-01-2025, 06:40 PM
      • Andre Gilbert
        by Andre Gilbert
        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
        11-20-2024, 08:52 PM
      • AquaMan Ua
        by AquaMan Ua
        05-17-2025, 09:40 AM
      • stecos
        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
        by stecos
        Hi everyone!
        For my passion for technology I'm now collecting several...
        11-28-2022, 11:39 AM
      • aa10aa10
        Panasonic Toughbook CF-33 mk1 BIOS repair
        by aa10aa10
        Good day,
        I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
        I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
        01-21-2025, 06:13 AM
