Panasonic TH-42PX80E
  • PowerAmpFreak
    • 982
    • Sweden
    Panasonic plasma, TH-42PX80E enters standby mode as soon as the powercord is connected to mains. A few relays click. Nothing further.
    Unable to get set enter operating mode by buttons. VA and VS never comes up.
    Is this a power problem or mainboard problem ??
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TH-42PX80E
    Not sure if it's PSU but your PSU could be similar design to this, I'd check those parts.
    From memory the fuses, wirewound resistor and Q406 can blow.
      You should get two clicks from relays, then a 20 second delay (or thereabouts) with one final click. If an error occurs during that or after that you'll get a blink code. Or does it just click on and freeze? If so I'd be thinking main board.
      • Andre Gilbert
        by Andre Gilbert
        11-20-2024, 08:52 PM
      • AquaMan Ua
        Problem with PANASONIC CF53 laptop after changing BIOS settings
        by AquaMan Ua
        Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
        05-17-2025, 09:40 AM
      • stecos
        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
        by stecos
        Hi everyone!
        I happened several times, in the search for help from the web, to consult this very interesting forum.
        So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
        Having said that I come to the gist of my post on the forum as the title suggests.
        For my passion for technology I'm now collecting several...
        11-28-2022, 11:39 AM
      • aa10aa10
        Panasonic Toughbook CF-33 mk1 BIOS repair
        by aa10aa10
        Good day,
        I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
        I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
        01-21-2025, 06:13 AM
      • Mnawar27
        Panasonic CF-H2AU24EF3 bios locked
        by Mnawar27
        Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
        I need help to remove it,
        thankyou all.
        SN; 2FKCA26876...
        11-16-2024, 08:00 AM
