Well have another for you guys. Here's the history. The guy I got this from said it is only 8 months old. He said it just stopped working.They had a repair guy come out wanted 250.00 to repair.Here's what it's doing. plug into outlet orange vizio light comes on.Press power button vizio light turns white,then get vizio slash screen for a second then goes off and back to white vizio light.white vizio flashes once and when goes back to orange vizio light. it does this every time you hit the power button. no other buttons work menu,av etc. Only have 5.v no 12v 18v or 24 volt I have read the threads on this matter for other tv's some say main board others say PSB or inverter. Hope you guys can help sort this out. this is a nice tv.I will post pictures
					Vizio E552VLE turns on then off
	Tags: None
Re: Vizio E552VLE turns on then off
Since you have backlight even briefly, you -will- have 24V. You need to check if it is stable or not.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Tom66, I checked 24v on power board at CN4 all the black wires read o.o but there is a white wire that's labeled 24v and it is not stable it is reading 0 volts to 30 volts and it just keeps cycling from 0v to 30vComment
30V? Is your multimeter an autoranging type or one set to a manual range? If unsure, post a picture of it.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
OK, can you set it to a fixed 200V DC range. This is usually done by pressing the RANGE button until the required range is reached. Then re-measure the 24V and see if it is still overshooting. Reason for doing this is many autoranging meters will over-shoot on fast changing voltages.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Changed meters reads 0 volts nowOK, can you set it to a fixed 200V DC range. This is usually done by pressing the RANGE button until the required range is reached. Then re-measure the 24V and see if it is still overshooting. Reason for doing this is many autoranging meters will over-shoot on fast changing voltages.Comment
But you still get backlight briefly? Would mean your meter is at fault or you are testing it wrong.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Yes. The backlight should also light up briefly.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
OK. Next step. Locate the PSON line and see if that is stable.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Hmm... Odd labelling... I think it is REMODE. A possible typo from REMOTE, sometimes what PSON is called.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Mkay, you're probably looking at a main board fault.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
			by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
			by judamexMacBook Air turns on without battery connected, no green or orange light comes on, I connect the battery and it shows battery with lightning and it restarts constantly.
			by Super360Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
Assuming...7 Photos -
			by ArkieredHi everyone, I am looking for a schematic diagram for the Main Board to a Vizio E552VLE. I have 5V Stby good and solid, but I get no Pwr On signal. If I jumper 5V to it, the Power Supply has 12 and 24V, but I also get no signal to turn the backlights on. Any help is appreciated, Thanks.
 - Loading...
