Vizio P50HDTV10A Sound No Pix
  • dfergy54
    • Jun 2013
    • 57
    Re: Vizio P50HDTV10A Sound No Pix
    Hers a pix of the board for reference.
    If it ain,t broke.......
    If all the smoke is still in it, it should work,
    • dfergy54
      • Jun 2013
      • 57
      Should have attached this one too.
      • dfergy54
        • Jun 2013
        • 57
        Is a complete picture frame loaded and then strobed/sustained by the Ysus at a time or is each Line loaded and strobed in sequence, top To bottom?
        I know you guys and Gals don,t have a magic wand and I appreciate all the input, I have actually learned quite a bit but barely scratched the surface.
        Actually considering raiding my main, the P50HDTV20 to try and make sense out of this 10. Not really thinking thats a wise move, most boards won,t be compatable, except maybe the one I already relaced.
        Might be better off to just re skin it and wait for another 10, in the mean time I just pick on it a little when I get a wild hair.
        Regards
        David
        • dfergy54
          • Jun 2013
          • 57
          Regards
          David
          • capkid
            • Oct 2010
            • 1339
            Unless your two TVs' main boards have the same part number, I wouldn't swap the main boards. I still might be a bit nervous about taking the main board out of a working TV. You can check shopjimmy.com for compatibility.
            LG Plasma Mal-Discharge Correction Service
            • dfergy54
              • Jun 2013
              • 57
              Thanks Cap Kid, I,ll check that out.
              • ChaosLegionnaire
                by ChaosLegionnaire
                09-13-2022, 09:02 AM
              • ggil44
                Vizio M65-E0 No Picture, No Sound
                by ggil44
                Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                09-03-2024, 08:30 PM
              • LEECH666
                Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                by LEECH666
                Good day ladies and gentleman!
                I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                01-19-2024, 05:46 PM
              • ajshoe
                vizio E60-E3 backlights, sound, no video
                by ajshoe
                Have a free Vizio E60-E3 pickup - sound and backlights work. set turns on and stays on for a period then cycles off and back on. NO VIDEO. If I remove left side (from front of TV) of TCON cable - set has pic on right side (from front of TV) with white screen on left side. With right side TCON cable disconnected - no pic on either side.
                Does this mean remove right side (from front of TV) tabs ?
                Like a second opinion before possibly destroying set....
                04-07-2023, 01:59 PM
