Vizio V042L Completely dead!
  • k370
    Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
    by k370
    I have a NM-A321 board that is dead, with no power at all.
    When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
    With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
    • +3VALW
    • +5VAUX
    • 1.2VSUS_PWRGD
    • 3VALW_PGD
    • 1.05VAUX_PWRGD
    Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
    The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
    09-23-2024, 11:57 AM
  • fharris1977
    Vizio D50u-D1 Dead: PSU or Main Board?
    by fharris1977
    Hi. Anyone who has experience with these vizio sets, which pin on this connector is the standby, the 5V pin? Trying to rule out the PSU before ordering a mainboard. I'm getting 0 Volts on all pins on this connector. Trying to jump the standby and PS ON pins to see if the PSU is functioning. Thanks in advance.
    03-12-2024, 12:22 PM
  • corrize
    Nikon D5 – dead, power board issue ?
    by corrize
    Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
    When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
    I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
    Now, I try to understand how it works.
    There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
    04-03-2023, 09:13 AM
  • Asraf Atb
    by Asraf Atb
    01-27-2025, 05:02 PM
