Samsung LE37A556 Screen Fades to white / Bleaches out
  • DemonBG
    • Mar 2012
    • 143
    Hello Everyone,
    My brothers 37" Samsung has recently started acting up and i am wanting some of your wisdom to try and diagnose / fix it.
    Background:
    I bought the TV about a year ago, faulty. The fault was down to a failed capacitor on the power board. The TV booted up fine but gradually got darker (as though the brightness settings were changing) until the screen was too black to watch (Still could see an image but barely).
    The capacitor was not the best quality cap on the market (cannot remember the brand) but was what i had lying around at the time. That was replaced and the TV has been fine until now.
    The problem:
    The TV boots up fine and the image is good. After about 5 minutes though the screen starts turning white and keeps gradually getting whiter until the screen is almost completely blank after about another minute or two (you can still just about see an image but very faintly).
    What i have tried:
    I have been told that this sometimes happens due to the boards connected to the LCD panel itself (Not sure what they are called) distort and short. I have followed the advice given here: http://jkturner.net/samsung/ with no joy.
    All cabled have been checked over and reseated but again, no joy.
    The fact that this happens after a few minutes makes me think it is heat related - possibly the T-Con board?
    Will attach pictures as soon as i can.
    Thanks in advance,
    Demon
  • DemonBG
    • Mar 2012
    • 143
    Re: Samsung LE37A556 Screen Fades to white / Bleaches out
    Pictures of the TV doing its thing. First pic is as booted, second is after about 3 minutes, third is after 5 minutes
    I dont have any pictures of any of the boards at the moment (May do this weekend) but the T-Con part number:
    T-Con Board: T30hw02 v402 37t040c02
    Thanks again all,
    Demon
      I would consider heating up parts of the set to try & narrow down the fault.
      • DemonBG
        • Mar 2012
        • 143
        Hi Tom,
        Ok so i spend the day trying to see if i can narrow the fault down to no avail. It seems the problem was getting worse in the hot weather to the extent that it was white within seconds of turning the screen on - Not enough time to know if the heat had anything to do with it at all...
        Either way now i have a fresh problem... In my infinate wisdom and frustration i decided to unplug and replug one of the two cables leading into the LDC panel from the Tcon board while the TV was on. Whatever i did was not a good idea as now i get no image at all on the screen (completely black screen) but i still get sound and the backlight still works.
        So... have i killed the set alltogether now or have i likely just fried the T-con board?
        Regards,
        Demon
        • Ken256
          • Oct 2009
          • 25
          Could be something shorted while you were plugging/unplugging the LCD connectors. If you can get it back to its original condition, where the screen would fade to white over minutes, you might be able to diagnose it with a voltmeter. The T-Con board generates or transmits bias and supply voltages. I would suspect some change in the bias voltages over time is causing the fade to white. Put a voltmeter on each voltage rail and see if it changes over time as the symptom worsens.
          • DemonBG
            • Mar 2012
            • 143
            Thank you for the reply Ken. I will order a new T-con board if i can find one and see if there is any improvement... For the moment i have a feeling i may have shorted something on the T-Con so will need to replace that first.
            Where are the test points on T-con boards though:
            Thanks,
            Demon
            • Ken256
              • Oct 2009
              • 25
              Check fuse F1, next to the input connector. See if it is blown.
              I would try probing the test points labeled, VGHC, VGL, VCOM, VCOMF, V12IN1, REF2,3...
              • DemonBG
                • Mar 2012
                • 143
                hi Ken,
                Thanks for the Input - I checked the fuse in situ when i was there and it was fine.
                As i said before im looking to replace the T-Con board. Only problem is i cant seem to find many of the part number i am after: "T370hw02 v402, 37t040c02"
                I can find plenty of these though: "37T04COG, T370HW02 VC"
                Apart from the mounting points they look fairly similar so i have no idea if it would be compatible or not?
                Any advice is always appreciated.
                Warm Regards,
                Demon
                  You have to match the numbers on the BARCODE sticker, the 'T370HW02' is the P/N of the blank board without components.
                  It looks like it has the same problem with AS15 IC, look under the heat transfering pad on the small IC on the left with square pad to see if it has AS15 number on it.
                    Yes and check VGMA1...VGMA22 voltage, the voltage should increase or decrease from each consecutive point.
                    • DemonBG
                      • Mar 2012
                      • 143
                      thank you all for the replies. From other posts i am lead to beleive it does have the AS15 chip which i also known is prone to fail...
                      I will be back with the TV this weekend and will do some more testing and get back to you all.
                      Thanks again,
                      Demon
                      • DemonBG
                        • Mar 2012
                        • 143
                        Update!
                        So the new T-con board arrived (The number on the barcode was slightly different) but both the numbers on the board itself were the same. Either way, i had nothing to lose so plugged it in and SUCCESS!!
                        TV booted up without a hitch and no longer fades to white! I am fairly sure it was down to that AS15 chip on the original board but it seems a new Tcon board has saved this one from the skip... at least for a little longer.
                        One thing i may do is get a stick-on heatsink and place it on the metal shielding directly above the AS15 to try help keep the heat down? Hopefully will save this one from the same fate.
                        Thanks again all for the help, i really appreciate it!
                        All the best,
                        Demon
                          Good news, you did transfer the thermal pads from the old board to the new board, right? or the new board does come with all the thermal pads.
                          • DemonBG
                            • Mar 2012
                            • 143
                            hi Bud,
                            Yes the new board (Purchased from Flattvparts) was pulled from a used TV so it came with all the pads installed.
                            Thanks again,
                            Demon
                            • harp
                              White screen repairs
                              by harp
                              To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                              Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                              On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                              05-13-2024, 03:43 AM
                            • Chrissygizmo
                              samsung galaxy ao2s very temperamental after screen replaced
                              by Chrissygizmo
                              Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                              Ive eventually managed to get it on and working but it's very temperamental...
                              The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                              05-26-2024, 12:05 AM
                            • JunkmanJimbo
                              Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                              by JunkmanJimbo
                              Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                              No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                              Please help. Thanks in advance!
                              08-12-2025, 11:45 AM
                            • Kiberge
                              Samsung LH82QENELGC/EN Help needed - Static line on screen
                              by Kiberge
                              HI guys!
                              I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                              I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                              the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                              This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                              04-22-2024, 11:28 AM
                            • Ryan.man
                              by Ryan.man
                              02-04-2025, 12:23 PM
