Philips Plasma 50PFP5332D/37
  • Xsoldier416
    • Jun 2013
    • 23
    So I have a broken plasma and I haven't quite figured out what's exactly wrong with it just yet. I followed a lot of the tips on Tom66's plasma fix-it guide and that has been informative if not helpful in learning things for future reference, I just haven't located the specific problem.
    To update on what I've checked thus far:
    1. I replaced the capacitors on the power board (almost all of them except the very large ones).
    2. I have tried all the various configurations of components plugged in and not plugged in through the power board.
    Through it all the relays click very steadily and nothing comes on. I am going to the store to grab some 400ohm resistors as per Tom's direction, but any other thoughts are of course welcome. Thanks.
    Re: Philips Plasma 50PFP5332D/37
    Can you please post pictures of the chassis and of each large board in the set.
    • Xsoldier416
      • Jun 2013
      • 23
      Here are the pictures of the boards and full back. I was unfortunately working with limited light sources, so if they're too dark or just not good enough in general I can bring in a couple more lamps and try again.
        Please try powering on set with these unplugged
        https://www.badcaps.net/forum/attach...9&d=1372211941
        https://www.badcaps.net/forum/attach...8&d=1372211941
        • Xsoldier416
          • Jun 2013
          • 23
          Both side boards are unplugged but the TV does not turn on. It just keeps clicking. With every click an LED on the main board, control board, and the little board right next the the main board, flash:
          https://www.badcaps.net/forum/images/attach/jpg.gif
            OK, can you measure the voltages on the connectors going from the power supply to the main board? Maybe some of the rails are not coming up.
            • Xsoldier416
              • Jun 2013
              • 23
              I do not have a multimeter. All I could find was a basic voltage indicator.
                You will need a digital multimeter to repair TVs. You can buy one for around $10 from many retail shops.
                • Xsoldier416
                  • Jun 2013
                  • 23
                  So I've had the DMM for a few days now and I just sat down to test the pins from the power to the main, but I can't see a good place to touch both sides from?
                    Black probe on chassis, red pin on each pin.
                    • Xsoldier416
                      • Jun 2013
                      • 23
                      For voltages starting with the first connector (1M02):
                      pin 7 - fluctuates between -2.5 and -3.6 mV
                      pin 6 - 17.28 V
                      pin 5 - 17.28 V
                      pin 4 - fluctuates between -.5 and -.9 mV
                      pin 3 - fluctuates between -.6 and -1.0 mV
                      pin 2 - -17.21 V
                      pin 1 - -17.21 V
                      Second connector (1M03):
                      NOTE: When this connector is unplugged the relays click faster.
                      pin 10 - NC
                      pin 9 - It says there should be no connection, but there is a wire there and it ramps up from 0 to 200 mV and then reverts back.
                      pin 8 - there's no wire although the board says that it should be DC_PROT
                      pin 7 - fluctuates with the speed of the relays from 0 to 2.5 V or so
                      pin 6 - NC
                      pin 5 - no wire, board says 5Vsw
                      pin 4 - fluctuates from -1.4 to -3.4 V
                      pin 3 - board says NC, but there's a wire and the pin ramps up from 0 to wherever and reverts
                      pin 2 - 5.31 V (board says 5Vatb)
                      pin 1 - board says NC, wire in the connector and the pin ramps from 0 and reverts
                      Third connector (1M46):
                      NOTE: when this connector is unplugged the control board powers on and stays on. Then when plugged back, while the TV is plugged in, the control board turns off and there are no more relay clicks.
                      pin 11 - 12.31 V (12Vssb)
                      pin 10 - NC
                      pin 9 - 12.31 V (12Vssb)
                      pin 8 - NC
                      pin 7 - 5.23 V (5Vatb)
                      pin 6 - -8.2 V board says GND_SSP, but there's no wire on the connector
                      pin 5 - 5.17 V (5Vsv) (no wire)
                      pin 4 - 12.31 V (12Vssb) (no wire)
                      pin 3 - NC
                      pin 2 - -7.6 V (GND_SSP)
                      pin 1 - -7.6 V (GND_SSP)
                      • Xsoldier416
                        • Jun 2013
                        • 23
                        Update: After a little more looking, I realized that the large board on the left (https://www.badcaps.net/forum/attach...8&d=1372211941) was not plugged in and after plugging it in, I unplugged the third connector and the screen comes on. That board on the left does make a loud hum though.
                          The screen glows slightly with that connected? Does the relay keep clicking?
                          • Xsoldier416
                            • Jun 2013
                            • 23
                            Starting with all of the boards connected, I unplugged the third connector (1M46) from the Power to the Main. This allows the control board and the far left boards (Ysus?) to power on, and the screen glows. However this means that the Main board is not on as none of the relays or in-board LED's on the Main board are lit.
                              Sounds like a main board problem, then.
                                Since this is using a Samsung panel, you can place a jumper across a test point on the control board to enable test patterns. Post a picture of your control board, this connects via LVDS to the main board.
                                • Xsoldier416
                                  • Jun 2013
                                  • 23
                                  Here is the control board.
                                    OK, CN2007 is your jumper block. See here:
                                    https://www.badcaps.net/forum/showpo...61&postcount=2
                                    • Xsoldier416
                                      • Jun 2013
                                      • 23
                                      I soldered a wire between pins 3 and 4, plugged everything in, and turned it on. The relays clicked repeatedly until I unplugged the third connector (1M46) from the power board. At that point the relays clicked once, the control board turned on, there was no power to the main board, the Ysus came on and then the screen started to go through several colors: white, green, red, blue, back to white with a scrolling black horizontally, then black scrolling vertically, and then a weird ripple effect coming from the bottom right hand corner. After all this it repeated. It seems the main board or the real small board right next to the main board is not working properly, creating the repeated clicking, and not allowing anything to turn on. Any thoughts?
                                        That would seem about right; the test pattern rules out the power supply, Y-main, Y-buffers, panel, control board and X-main.
                                        • celiabrown
                                          Issue with Plasma Philips 37inch chassis FTL2.1
                                          by celiabrown
                                          Hello guys,
                                          My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                                          Can someone has any symptom like this ?
                                          Thanks​
                                          05-09-2024, 10:56 PM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • janos6662000
                                          Philips 47PFS7509/12 LCD TV problem
                                          by janos6662000
                                          Hi
                                          I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                          When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                          I downloaded original firmware and applied the update, but the problem remained.
                                          From a colleague i received a "factory package software" which is a lot bigger.
                                          I made another firmware update, but still did not solve the problem.
                                          Somewhere on the way the error got worse, because at the moment the...
                                          08-12-2025, 12:54 PM
                                        • aidanmo
                                          Philips 43PUS7506/12 - Loud blown out sound
                                          by aidanmo
                                          I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                          I thought maybe the speakers got damaged, so I replaced them - no dice.
                                          • Using the internal speakers, it always happens.
                                          • Using the headphone jack, it never happens.
                                          • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                          02-28-2025, 03:13 PM
                                        • ib6
                                          philips 50pfp5332d/37 plasma both boards arcing
                                          by ib6
                                          I have a Philips plasma I'm trying to fix. I have the back off and have checked all the fuses and they are good. I don't see any bulging capacitors or any burned areas. The blue light comes on and I hear the clicking sound from the speakers but screen is black. I can unplug each sustain board but when I plug them back in they both give off a spark. It happens when the unit is unplugged and it has happened when its been unplugged for several days. I am not sure where to go from here and could use some insight on what to do next.
                                          An additional note - the set has never been used it...
                                          12-20-2017, 08:05 PM
