Vizio E321VL
    Re: Vizio E321VL
    Originally posted by ChipStewart View Post
    You mean the metal box on the board? Is it replaceable? Or is it part of the main board?
    ya, where the cable screws into, that can be de-soldered and replaced if ya know a bit of skill
    "Don't think inside the box, Don't think outside the box"......Just destroy the box!
      Re: Vizio E321VL
      I'm pretty good for an amateur. I've soldered the e321vl eprom, mini-usb jacks, etc. Any idea where to find one? Google didn't help.
        Re: Vizio E321VL
        Or is there something inside that can be fixed / replaced?
          Re: Vizio E321VL
          You need to look up the part # on them, but you probably won't be able to buy them unfortunately. You could buy a "converter box" (with composite out) and program the remote to operate the TV.
            Re: Vizio E321VL
            any external device w/ a tuner can be a substitute as well, although realize your input may be SD lo-res
            back to the Vizio E321VL problem.... ...lol
              Re: Vizio E321VL
              if anybodys interested i have this same exact tv that works perfect except for the screen getting cracked by a game controller. i may sell the boards to buy different parts for another project. just let me know. thanks and good luck
                Re: Vizio E321VL
                Hw00d,
                Did you ever get anywhere on this? I just fixed an E470VL with the exact same issue. Main board. I verified the power supply was good by jumping from the 5VSB to PS-ON. I then checked all voltage outputs on the supply as jumped another wire to BL-ON to make sure the backlights worked. At that point I was certain the main was bad. TV running smooth now.
