Simple Remote Control Test
  • signup
    • May 2013
    • 189
    Hi
    Just wanted to share this with those that dont know, and sorry if this has been shown here before
    A quick simple test for a remote control you think may be faulty is to put new/known good batteries in, then get your digital/phone camera out and look at the IR sensor through the lense of your digital/phone camera, your camera can pick up infa-red and you will see the light illuminating, giving you a good idea that its working
    Re: Simple Remote Control Test
    Yep, have used this a lot.
    Another nice trick is using an AM radio set to an empty band. Place it near the remote control and you should hear pulses.
    • signup
      • May 2013
      • 189
      Another great one to take on board, better than buying a remote tester that just gives a bleep
      Not knowing in depth how a remote works, would the pulse be different for each button, or would it be a case of we wouldnt hear the difference?
        You may be able to hear a slight difference but don't expect much.
        • Sevenqi
          • Jul 2011
          • 292
          I always used AM radio as Tom, when press any key, you should hear noices from the radio. If not, then your remote is not functional, may need to check battery, or clean/repair.
          • johnboy1313
            • Nov 2012
            • 1959
            Originally posted by signup
            Hi
            It doesn't work with my iPhone.
              Another reason not to get an iPhone then. It works on every other cell phone camera I have used (HTC One, various blackberry phones)
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                iphone = :barfphone
                Follow the white rabbit.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  Originally posted by goontron
                  iphone = :barfphone
                  Super nice of you. It's the nicest phone I've ever owned. Maybe you should talk bad about my kids too. I mean, your life is obviously so much better than mine.
                  • jbfr_54
                    • Dec 2012
                    • 52
                    • France
                    I personnally use a cheap digital camera to check the IR output. This does not mean the remote is fully functional, it just means it is delivering an IR signal to the set. I had a situation where the IR output was OK and bright but the remote still failing to control the set. Probably a problem in the remote circuit (wrong coding ??).
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      why are you steve jobs? notice my sig, open source runs the world and android is open source. you can go and download the code for it to! iphone nawww, apple's going "yay for DRM"
                      besides i'm sure your kids look great. ohh and ALL my towers were ones that were about to be thrown out or were already thrown out.
                        This is a stupid thing to fight over.
                        The iPhone has uses, like any smartphone, but I don't own any smartphone. I've never liked the sacrifices in ruggedness (most smartphones would shatter into pieces if dropped) or battery life (a day if you're lucky.)
                        Who cares what anyone else uses. If it makes them happy, it makes them happy.
                        • tmhobadcap
                          Pioneer VSX-522-K remote control not working???
                          by tmhobadcap
                          I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                          At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                          12-24-2020, 01:44 AM
                        • SluggerB
                          Help with trying to fix phone that is not charging (Pics inside)
                          by SluggerB
                          I have two TCL A30 phones.
                          Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                          New Phone: Works fine, bought as a donor board to try and repair Old Phone
                          My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                          08-12-2024, 08:11 AM
                        • piipo
                          Old Privileg 5.1 speakers remote control question
                          by piipo
                          Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
                          09-18-2024, 01:55 AM
                        • hemant_2222
                          Schematic for Denon Remote Control RC1156
                          by hemant_2222
                          Hello Everyone,
                          Hope everyone is enjoying their repairs at hand!.
                          I am looking forward to get the schematic of Denon remote control RC1156. Actually long time no use of the remote leaked the battery thereby corroding few parts as well as the tracks.
                          I was able to join few of them but the remote is still not working, so i am looking forward for your help, in case anyone understand the schematic or the remote circuit diagram and could me assist me in repairing it.
                          Please refer to the attached picture, i think the voltage divider is missing...
                          10-06-2023, 02:05 AM
                          1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
                          I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
                          This metal lathe has a weird motor setup it has a soft start motor with a “Y” and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
                          12-29-2024, 07:18 AM
