Sony KDL-40EX403 blinking LEDs.
    Hi guys, hope you can help.
    I have a Sony KDL-40EX403 which, when it came to me, would just switch from red standby light to green on light (solid). Since the screen didn't light up but the LEDs indicated it was on, I naturally assumed the problem was with the inverter which I replaced - twice before deciding the chances of receiving two faulty inverters from the same seller were slim enough to try something else.
    I replaced the main board (1-881-636-23) with one that I thought would be compatible from a KDL-40EX503. But when I put that board in I just got 5 blinking red lights recurring. The seller told me that this was down to firmware incompatibility and I needed a 1-881-636-23 with a BAL number A-1769-676-A specific to a KDL-40EX403 not a 503.
    Now, I've never actually dealt with a Sony TV - tend to stick to Toshiba, LG and Hitachi - so could only take him at his word. So I did what he said and ordered a 1-881-636-23 A-1769-676-A. When it arrived, the board had 'KDL-32EX403' written on the heatsink which I asked him about and he insisted it was still compatible.
    So I put it in and got a flashing green and amber light - both flashing in perfect unison. Disconnecting the T-con gave me the 5 blinking red lights I had observed with the previous board. I tried a factory reset and also tried a firmware update by USB. Same result, nothing changed.
    I have not idea if what the seller is telling me is truth or not and I feel like smashing the telly frankly. Any ideas you guys can offer would be greatly appreciated.
    I can solder of course, but tend to avoid it if I can because my eyesight isn't the best. In this case I don't know if the boards I have are faulty or not and don't want to void the warranty on them by pulling them apart unless I know for certain that is required.
    Re: Sony KDL-40EX403 blinking LEDs.
    Most Sony boards aren't interchangeable between models or screen sizes, so the seller probably was wrong to think a 32" board would work in a 40".
      Thanks for the swift response Tom66. Yeah I was somewhat dubious about the idea that 32" board would suffice although - at least insofar as Toshiba's go - I expected it to at least light up.
      In your experience my friend, would you be inclined to think this was a main board issue in the first place? Just want to be sure I am barking up the right tree here.
        I've never (successfully) repaired a Sony, so can't offer much help. However, I have heard of 5 blinks being down to corrupt firmware, so there's a chance it is the main board.
          Hi guys, I have an update on this fault.
          Working on a SONY KDL-40EX403, from standby (red) light turns green for around 2-3 seconds and then 2 red flashes. Not a firmware issue, it was the power supply APS-254 not turning on, so no 12V main for the SSB.
          Found Q6302-6303 s/c R6342 (0.1R Fusable) o/c Q6302-6303 ARE 2SK4096 I had no stock, substituted with STP9NK50ZFP.
          Set now fine.
            hi,I am trying to fix my board aps-254 and I need a R6342 (0.1R Fusable)
            any idea from where to buy one or some replacement .
            thx
              thx
              Farnell, CPC or eBay supplier. Got a picture of the component or more specifications?
                yes I have some photos taken .
                  Hi I replaced with this and is working now
                  FRN25JR22 FUSIBLE Resistor 0.22ohms 1/4watt 0R22
