vizio E320-A1 not working
  • lolaeng
    • May 2017
    • 23
    Re: vizio E320-A1 not working
    I've reinstalled the main board. The PN of the little 8 pin eeprom with the white dot does begin with 25. So I have 5 items to test. How to test each and what I am looking for is not clear to me. Can anybody please instruct me?
    • dskall
      • Oct 2016
      • 2905
      • usa
      #82
      Refer to post 76
      • lolaeng
        • May 2017
        • 23
        I sprayed until it got nice and frosty, then pressed the on button more than once. The same thing happened that has been happening for the past several days...nothing. So now do I test the ics? If yes I need instructions please and thanks.
        • lolaeng
          • May 2017
          • 23
          From watching youtube videos by repair guys, Vizios have a lot of problems similar to mine. One vidio specifically addressed my problem but on the E320-A0; mine is the -A1 which is a bit more detailed. The repair guy tested an eight-pin eeprom similar to the one pointed out by dskall in post #76.
          Assuming the black probe should be grounded via something on the pcb itself, like a screw, I tested each of the 8 pins and some were around 3.3 dcvs and some were mVs and some were 0 whatever. So I am guessing that eeprom may have problem.
          I'm here hoping one of you, realizing I know practically nothing, is willing to guide me. I'd buy willingly a new main board BUT they no longer are available. One thing I've learned from all this is there are simple solutions. It is not necessary to throw into a landfill an entire TV; it is fixable. I want to learn just what is broken, then I'll go to somebody who can fix it, but won't be able to snow me.
          Thanks.
          • dskall
            • Oct 2016
            • 2905
            • usa
            #85
            E320 suffer a lot from bad eeproms and there are lots of eeroms on ebay etc. Was hoping freezing or heating would confirm the problem. That's a cheap and easy fix.
            • lolaeng
              • May 2017
              • 23
              So, where can I go for help? Here hasn't helped. Will somebody answer my questions re how to test or tell me about another online place that can?"
                http://www.shopjimmy.com/catalogsear...vizio+E320-A1+
                There are main board repair kits.
                BTW, so let you find the bad component/s, do you have the proper tools to do surface mount component level repair?
                "Here hasn't helped. Will somebody answer my questions re how to test or tell me about another online place that can?" sorry to hear that from you.
                • lolaeng
                  • May 2017
                  • 23
                  So, where can I go for help? Will somebody answer my questions re how to test or tell me about another online place that can?"
                    1) Look up the spec sheet of the EEPROM and study on how it function and see which pins are for.
                    2) Buy an oscilloscope (and learn how to use it) and your DMM so you can look at the signals of the EEPROM.
                    3) And to go further then try locating the schematic diagram so you can trace signals and Voltages to see if they are correct or not.
                    4) Search how to test EEPROM. I.E.: http://www.microchip.com/forums/m214728.aspx
                    5) Or get EEPROM (u409? or U403? due to more than one version of the main board) from shopjimmy or main board repair kit.
                    Is this the Video you watch?
                    https://www.youtube.com/watch?v=Sghh8BK5zIw
                    It is the same topology that can be applied to your TV and may others TV as well.
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      #90
                      Trying to help but i'm through with you.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #91
                        we are all trying to help you repair your tv regarding post 72 voltage regulator testing have you now tested all of these and what was the results? please note for us the part number of the regulator and the voltage reading on each pin
                        • lolaeng
                          • May 2017
                          • 23
                          I'm sorry, dskall, you feel that way. It seems the underlying assumption by most participants here is that I understand everything said and how to execute on all suggestions given. I don't. I need an "ICs for Dummies" manual. So I've watched oodles of videos, including, budm, the one you linked re the Vizio e320-A0.
                          Of all the videos I've watched ONLY 2 have either shown or mentioned to what the black probe should be connected to ground. One said "on the main board near the ic being tested" the other simply grounded it via the metal in the back. So, I finally just stuck the negative probe in a metal hole in the back of the tv and tested every eeprom and voltage regulator visible hoping I was doing it correctly. Results below.
                          budm suggested?
                          "1) Look up the spec sheet of the EEPROM and study on how it function and see which pins are for."
                          ...Google was useless in helping me figure out where the heck to find spec sheets. Thanks for assuming I know more than I do.
                          2) and 3) these suggestions go beyond my level of competence at this point.
                          4) The language used at http://www.microchip.com/forums/m214728.aspx
                          might as well be in Greek, Russian, or Chinese.
                          TEST RESULTS
                          All readings are DC vs except where noted. All eeproms ON THE BOARD are upside down. So I flipped them over on paper and started the readings from the pin at the top left. The pins with white dots are all, therefore, bottom row left end.
                          I'm listing the ics starting at the ic at the top right, going counter clockwise ending at the ic at bottom center of the main board. See photo for more info.
                          U702
                          TAB: 1.2
                          L: 0
                          M: 1.2
                          R: 3.27
                          U703
                          TAB: 3.27
                          L: 2.03
                          M: 3.27
                          R: 5.27
                          U408
                          3.27
                          3.26
                          3.26
                          3.26
                          WD: 3.26 (WD = white dot)
                          2.51
                          3.27
                          0
                          U409
                          3.27
                          3.27
                          2.5
                          2.5
                          WD: 3.27
                          2.52
                          3.27
                          0
                          U705
                          4.65
                          .57
                          1.2
                          1.2
                          WD: 12.2
                          12.3
                          12.3
                          12.3
                          Q104
                          12.23
                          12.36
                          12.36
                          12.36
                          WD: 0
                          0
                          0
                          0
                          U701
                          TAB: 3.28
                          0
                          3.28
                          5.21
                          Q702
                          5.22
                          5.22
                          5.22
                          5.22
                          WD: 5.22
                          5.22
                          5.22
                          28.0mV
                          U102
                          TAB: 3.28
                          0
                          3.28
                          5.21
                          • lolaeng
                            • May 2017
                            • 23
                            Thank you for your patience with me!
                              Post 89 #5 "5) Or get EEPROM (u409? or U403? due to more than one version of the main board) from shopjimmy or main board repair kit."
                              Go to shopjimmy .com and type in your TV model number and then which main board you have, shopjimmy shows you how to get the correct main board P/N thewn look at all the EEPROM replacement for you board number so you can locate the EEPROM part designator it may be U403 or U409, once you know which U that is then look at the printing on top of the IC and search for the spec sheet for that EEPROM so you can see which is what so we can probe the correct pins of the EEPROM. Without know the EEPROM number to get the spec sheet then you will not know which pins to test..
                              So get the correct P/N of your main board first.
                                BTW, if it turns out to be bad EEPROM or bad regulator, what are you going to do next since you do not have the tools to do SMD repair or any experience doing SMD works?
                                  "budm suggested?
                                  ...Google was useless in helping me figure out where the heck to find spec sheets. Thanks for assuming I know more than I do. "
                                  Well did you even try typing the numbers you found on the IC to see what comes up. I.E. IN POST 92 ONE OF THE IC 24C64F to see what come up?
                                  https://www.badcaps.net/forum/attach...2&d=1494988928
                                  • lolaeng
                                    • May 2017
                                    • 23
                                    With all due respect, budm, you may be an electronics wizard, but your command of English is lacking to the degree that what you write is not intelligible. Your sentences are incomplete and incomprehensible.
                                    NOT A COMPREHENSIBLE SENTENCE: Post 89 #5 "5) Or get EEPROM (u409? or U403? due to more than one version of the main board) from shopjimmy or main board repair kit.
                                    NOT A COMPREHENSIBLE SENTENCE: Go to shopjimmy .com and type in your TV model number and then which main board you have, shopjimmy shows you how to get the correct main board P/N thewn look at all the EEPROM replacement for you board number so you can locate the EEPROM part designator it may be U403 or U409, once you know which U that is then look at the printing on top of the IC and search for the spec sheet for that EEPROM so you can see which is what so we can probe the correct pins of the EEPROM. Without know the EEPROM number to get the spec sheet then you will not know which pins to test..
                                    I did go to shopjimmy.com. I did search there for numerous P/Ns, including the main board P/N which is out of stock. If I had gotten results there to help me I'd not come back here. I just listed in my post #92, including P/Ns in the photo, ALL the info I've been able so far to assemble.
                                    Are there any older dudes hanging out here who speak in full comprehensible sentences and can communicate?
                                      "Are there any older dudes hanging out here who speak in full comprehensible sentences and can communicate?"
                                      Sorry, English is my second language!
                                      So what id your main board P/N?
                                      Do you expect me to be able to read all those numbers on the barcode sticker using that picture in post 92?
                                        Repeat:
                                        If it turns out to be bad EEPROM or bad regulator, what are you going to do next since you do not have the tools to do SMD repair or any experience doing SMD works?
                                        BTW, sorry if the question is not clear enough for you.
                                          Is this your board, Vizio 756TXCCB02K033 Main Board for E320-A1?
                                          http://www.shopjimmy.com/vizio-756tx...r-e320-a1.htm#
                                          If it is, then I suggest you to buy the repair kit:
                                          http://www.shopjimmy.com/vizio-756tx...or-e320-a1.htm
                                          The kit is for fixing the following symptoms:
                                          SKU: sj-756TXCCB02K033 Repair Kit
                                          Part Number: 756TXCCB02K033 Repair Kit
                                          Warranty: No Warranty
                                          TV Brands: Vizio
                                          Specifications: Kit Includes
                                          Part 1
                                          Symptoms:
                                          -TV turns on (White LED is on) but there is no backlight.
                                          - TV will not turn off once it’s on.
                                          Description Quantity Board Location
                                          Integrated Circuits 1 Included With Kit
                                          Part 2
                                          Symptoms:
                                          - TV will not turn on (power indicator LED is off)
                                          Integrated Circuits 3 Included With Kit
                                          So if it is matched your problem then this should fix it.
                                          • mrtek
                                            Vizio M65-C1
                                            by mrtek
                                            Hi.
                                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                            07-14-2025, 07:28 PM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
                                          • MisterAIL
                                            PS5 digital / No Power / No Beep / Good power supply
                                            by MisterAIL
                                            Brought a non functionnal PS5. Apparently only a bad PSU...
                                            No beep, nothing.
                                            After some tests i found this :
                                            - PSU is fine (12 volts stable)
                                            - 12 volts line is shorted
                                            - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                            - By the way, nothing change. No signal, no power, no beep.
                                            Mesuring all rails with my workbench psu (12 volts input)
                                            - 0.00 amp drawing
                                            - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                            03-12-2024, 03:24 PM
                                          • Mcfeetroy
                                            Fishing bite alarm drains battery
                                            by Mcfeetroy
                                            Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                                            08-01-2025, 03:52 AM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
