HITACHI 42HDS69 Plasma random Vertical lines in middle of screen
  • Jeremy112
    • Sep 2012
    • 18
    I have a Hitachi 42HDS69 plasma TV that works perfectly for about 15-20 minutes and then in the near middle of the screen, about 2 inches wide from top to bottom, there are vertical lines spaced about 1/8 of an inch apart, so about 30 or 40 lines that you see.
    Now the odd thing is they are random in that they go away (mostly) and come back while viewing the source.
    This does this whether a signal is input or not. What would be the cause?
    Re: HITACHI 42HDS69 Plasma random Vertical lines in middle of screen
    When the problem occurs, is the whole screen covered in lines, or just a small section?
    • Jeremy112
      • Sep 2012
      • 18
      Just a small 2 inch wide section, the rest of the TV looks normal.
      • Jeremy112
        • Sep 2012
        • 18
        Just wanted to add, I'm testing the TV out right now and I think its a heat related issue, when the TV is off and cools back down, it does not have the lines, after getting to a certain temperature it starts to display the lines.
        I say this because its been about 40 minutes and the TV hasn't exhibited the line issue, but the TV isn't really warm yet either...
        • Jeremy112
          • Sep 2012
          • 18
          I figured some pictures would better illustrate the issue. I took 2 photos. One shows the green lines, one shows when they get less noticeable/almost go away.
            OK, it is likely a loose connector... Post a picture of the inside of your TV.
            • Jeremy112
              • Sep 2012
              • 18
              Ok here's the inside of the set.
              • capkid
                • Oct 2010
                • 1339
                I'll let Tom chime in, but my guess at where he was going is that there are address boards that run along the bottom of the panel behind the A/V board. One of the ribbon cable connectors between the address board and the panel in the vicinity of the defect may be loose. I'd also check the connections between the control board and the address boards.
                LG Plasma Mal-Discharge Correction Service
                • Jeremy112
                  • Sep 2012
                  • 18
                  Well I thought you would all like to know, I went ahead and removed the input panel on the back of the TV, and saw the connections (think its called the Z buffer?) on the side of the panel that the issue was on (I marked the width of the bezel where the lines were so I could see the area while looking at the back of the TV)
                  The problem area was right where the connection to the buffer board went, I unplugged it, cleaned it with isopropyl alcohol, and plugged it back in and its working perfectly, heck, I even notice improvement on overall image quality.
                  Figured you would all like a pic to see the working product. Thanks to all for your help!!
                  • capkid
                    • Oct 2010
                    • 1339
                    It's amazing how easily flat panel TVs can develop these simple issues. Enjoy!
                    • bossman103
                      • Sep 2013
                      • 4
                      Sorry for bumping an old post but this is exactly what I am running into right now
                      I have a friend that is quite knowledgeable in this and we've already changed the ysus board to only find out problem still occurs :-(
                      How did you fix this and where would I find this z buffer you speak of ? Please let me know
                      • bossman103
                        • Sep 2013
                        • 4
                        If you could point me in the area on your post #7 I would give it a whirl
                          It's different for each TV. You'd need to look at the connectors underneath the main board/AV board assembly.
                          • bossman103
                            • Sep 2013
                            • 4
                            Sorry forgot to mention, I have the 42HDS69 as well so same exact tv with exact problem :-(
                              Connectors are under here. You need to remove a lot of stuff to get at them, before doing so take a piece of tape and put it on part of the panel which is faulty as a marker for which connector is likely causing the problem. The connections must only be adjusted with power off.
                              • bossman103
                                • Sep 2013
                                • 4
                                Thanks ill give it a whirl tomorrow or Monday, I don't have much to lose as it doesn't work now anyways
                                • CNY_Dave
                                  • Aug 2017
                                  I was just given one of these, due to the stripe.
                                  This weekend I'm going in!
                                  Dave
                                  • howardc64
                                    by howardc64
                                    07-24-2025, 05:17 PM
                                  • kdaniel
                                    Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
                                    by kdaniel
                                    As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
                                    There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
                                    After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
                                    Left...
                                    11-16-2022, 09:23 AM
                                  • Vspeed
                                    LCD 31MU97Z displays random lines randomly
                                    by Vspeed
                                    I have this monitor which had the known issue with the corrupted flash. That is solved, now, after some time it started to cut the image from time to time and just display grayish random vertical lines. After some minutes the image usually comes back, until it does the same again.
                                    I took it apart and the only think that I noticed was ZD1 protection diode on the TCON board reaching 90ºC when it's showing this erratic behavior. I measured the voltage on the fuse right beside it, and is measuring 15.3V (under load). Without the TCON board connected, the connector measures 18.3V....
                                    01-22-2023, 02:26 PM
                                  • Stanley1843
                                    by Stanley1843
                                    06-29-2024, 11:54 AM
                                  • Rubenlily
                                    Samsung QE50Q67TAU - horizontal lines
                                    by Rubenlily
                                    First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                                    I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                                    I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                                    I'm no expert but I've done the tape...
                                    08-16-2023, 01:12 PM
