Sanyo dp46819 left side screen black
  • superdad2013
    • Mar 2013
    • 8
    • usa
    hi all I have a Sanyo dp46819 lcd and the left side if the picture is black....the backlight is good and when I touch the panel u see the liquid like The good side.. the line runs right through middle of screen and from middle to left up and down its all black...when its on a black background I can see the left side is a tad darker.. would like to fix it.. please help..
  • superdad2013
    • Mar 2013
    • 8
    • usa
    Re: Sanyo dp46819 left side screen black
    another pic.
      There should be two flat white cable between the T-CON and the LCD PANEL, it looks like the left side cable may not be connected or the drive for that side is dead. See post 10 for the pictures of typical flat white ribbon cables.
      https://www.badcaps.net/forum/showth...ight=LG+47LH55
      Did it happen all the suddenly?
        Tab bond defect
        https://www.youtube.com/watch?v=purk_SyiT44
        (Same cause - symptoms vary from no picture in affected half to scrambled/unstable picture or vertical lines.)
        • Irishblood
          • Mar 2015
          Need help with this too. Don't have any technical knowledge and wondering if it's worth fixing
          • ravi_1617
            HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
            by ravi_1617
            Hello to all ,
            I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
            Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
            on external VGA port image is perfect /normal , Attached image...
            07-25-2025, 12:07 AM
          • valvashon
            Samsung UN60JU6500, stripe on left side of screen
            by valvashon
            Friend sent me this picture of what their 60" Samsung from 2015 is doing. I didn't have any luck getting rid of a vertical stripe in another TV that developed one so I'm not too excited about trying to fix this one. It's mine for the asking; wish it had a dead power supply or bad backlights instead.
            Is this most likely to be a connection at the circuit board or where the ribbon cable hits the screen itself?
            Update: was just informed that this stripe comes and goes and has been doing this for a couple of months.
            Thanks, Val
            Yesterday, 03:01 PM
          • kca
            by kca
            Hello all ~
            08-31-2025, 06:38 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
