Vizio M420NV problems
  • mcross
    • Sep 2011
    • 201
    Ok heres one for you. got this vizio M420NV LED TV.
    powers on to logo screen then off, cycles on and off a few times by its self, then stays on logo screen, but just stays there. can not turn off, remote will not power on or off, button will not ether. have to unplug.
    mike
    Re: Vizio M420NV problems
    Corrupt EEPROM/flash chip. Replacement chip I think is about $25.
    • mcross
      • Sep 2011
      • 201
      thanks will try that
      Mike
      • mcross
        • Sep 2011
        • 201
        I found a main board cheap, but has a reversed picture, is that a setting? never seen before
        Mike
        • mcross
          • Sep 2011
          • 201
          Tom, I had a thought and heated the main board witha heat gun and it came on , went to the menu, ect.. , would you still think eprom?
          • attainteddragon
            • Apr 2013
            • 764
            • australia
            i have heard of vizios with a non shut down issue caused by a stuffed voltage regulator on the main! always worth a look!
            WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
              Probably not EEPROM then. Processor could have BGA failure, like Xbox 360 RROD.
              • mcross
                • Sep 2011
                • 201
                Main board has a regulator u4 1117 reads pin 1 0.00 pin 2 1.00 pin 3 3.10 is that right?
                  Doesn't seem right. Double check readings, also can you get full part number e.g. AK1117-33.
                  • johnboy1313
                    • Nov 2012
                    • 1959
                    I've read that reflowing the IC (the same one that seems to get the corrupt EEPROM) sometimes fixes these. Maybe you have a cold solder joint somewhere.
                    • mcross
                      • Sep 2011
                      • 201
                      Its good, had my meter on 200v reads pin 1=0.00 pin 2=1.24 pin 3=3.35
                      part number is OFf 1117 no other #s on on it
                      Also did you see my post about the reversed picture ? found a cheap main board but pic is reversed?
                        Output appears correct then.
                        May be possible to fix reversed picture if you can get into service menu.
                        • mcross
                          • Sep 2011
                          • 201
                          Tom,
                          Would i need just the regular remote to do that?
                            I don't know if these Vizios even have a service menu....
                            • richpart
                              • May 2012
                              • 42
                              Verify both old and new eeprom numbers are exact match. I used an eeprom for testing once that was close but not exact and it produced a reversed picture.
                              • SgtRock
                                • Feb 2012
                                • 175
                                Dear Mcross:
                                --You can get a M420NV Manual here:
                                "Measure twice. Cut once"
                                Norm Abram 1950 -
                                Best Regards
                                Clear Ether
                                • Bob1394
                                  Vizio M65-C1 | Logo appears for 10 seconds then off
                                  by Bob1394
                                  I have used the search, and am stumped.
                                  My Vizio M65-C1, Vizio logo appears for about 10 seconds then goes off.Power LED blinks 15 times then the TV powers down.
                                  I have read through many threads on the M65-C1 including the following threads. I feel like I must be looking right past the solution to my problem:
                                  https://www.badcaps.net/forum/showthread.php?t=81088
                                  https://www.badcaps.net/forum/showthread.php?t=84241 (not clear on the Eprom actions)
                                  Observations
                                  1) [Interaction] Power turned on via TV button (or remote)...
                                  02-08-2023, 01:03 PM
                                • Super360
                                  Vizio E701i-A3 Vizio logo flashing then turns off
                                  by Super360
                                  Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                                  07-25-2024, 07:06 PM
                                • x_orange90_x
                                  Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                  by x_orange90_x
                                  I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                  12-28-2023, 06:26 AM
                                • JaquesPratt
                                  Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                  by JaquesPratt
                                  I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                  This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                  07-16-2024, 01:04 AM
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
