Not as lucky as I'd hoped, Westinghouse LD-4255VX
  • johnboy1313
    • Nov 2012
    • 1959
    https://www.badcaps.net/forum/showth...t=westinghouse
    I'd seen a lot of the above thread the last few weeks and have been looking to get my hands on a non-working Westinghouse LED. Last night an LD-4255VX with the same symptoms pops up on Craigslist for a price I can deal with. I went and picked it up today. There's a little door on the back to access the mainboard without removing the back. I undid the top ribbon, plugged it in, and tried to power it on. No dice, just a red LED on the front when plugged in. I unplugged it, re-inserted the top ribbon, undid the bottom ribbon, and plugged it back in. Still no dice, still just a solid red LED on front. I pulled the cover off and removed the main board from the TV. I immediately saw the fried IC in the pic below. Ugh, this is a super expensive board. Just my luck
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Not as lucky as I'd hoped, Westinghouse LD-4255VX
    I'll try to get a pic to see if we can read a part number.
      It's the HDMI receiver IC... Probably not readily available due to copyright protection. Try removing it: the set will probably work without HDMI.
      • johnboy1313
        • Nov 2012
        • 1959
        I'll try it. Thanks
        • johnboy1313
          • Nov 2012
          • 1959
          No luck.
            You probably had a surge which killed the HDMI and many other components. Tracing down the fault may be next to impossible. New board time, I guess... Sorry...
            • johnboy1313
              • Nov 2012
              • 1959
              I may just stick this one under the counter until I can find a replacement board.
              • raptor49
                • May 2013
                • 14
                Sorry it didn't work out for you, and you probably already know this, but it's a different mobo, different tv than the one in that tread. 42" vs 46"......just saying.
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  Looks like an entirely different board. Ours have Zoran processors.
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    The symptoms sound like a Westinghouse monitor that was going to be given to me, but it had a blue LED lit. Just makes me suspect an IC got fried in it too during power trouble in Hudson, Massachusetts.
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      What's the likely outcome of using the board from a smaller set? No picture?? Mangled picture?? They look identical but there's about a hundred dollar difference in price.
                      http://www.shopjimmy.com/westinghous...2a-version.htm
                      vs
                      http://www.shopjimmy.com/westinghous...-ld-2657df.htm
                        What is the panel in your model? The 26" is:
                        K260H1-E03 Rev 01
                        If you have the equivalent, but 42", it should work.
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          I will look this evening. Thanks for the reply.
                          • johnboy1313
                            • Nov 2012
                            • 1959
                            It looks like my panel may be K420H2-E01 Rev 01
                            http://www.shopjimmy.com/westinghous...-version-1.htm
                            Does that sound like an equivalent? I'm still going to open it back up and confirm the panel before I buy anything.
                              Is there any T-con on this model?
                              I can't find any datasheet for the panel. Problem is, one could be e.g. 720p (likely if it is a 26") and this might be 1080p?
                              • johnboy1313
                                • Nov 2012
                                • 1959
                                Looks like they're both 1080p. The difference that stands out and will likely prove to be the deal breaker is the 42" is 120Hz while the 26" is only 60Hz.
                                  That would be the end of it all if the main board has 120Hz output. Does the 42" have a T-con?
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    Yeah
                                      Pic of T-con?
                                      • johnboy1313
                                        • Nov 2012
                                        • 1959
                                        I'm heading home now. I'll get it shortly.
                                        • zesko
                                          xps 9520 ribbon cable
                                          by zesko
                                          I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
                                          There is 2 models, idk which one is needed on my laptop.
                                          0xkvng
                                          00vpr2
                                          Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
                                          Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
                                          thanks...
                                          10-23-2025, 05:03 PM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • Rubenlily
                                          Quick question about the ribbon
                                          by Rubenlily
                                          Hey,
                                          So I have horizontal lines on my TV and I'm trying to trouble shoot. My question about the ribbon is:
                                          When I disconnect one ribbon from the t-con I should get half picture working and other half black or something like that correct? But when I disconnect the ribbon on one side I just get a dark screen and it doesn't matter what side I disconnect. I just get the dark screen. No half working, no one half black and the other one left. Sound is playing from the TV so it's obviously on and when both sides are connected I have the picture with the horizontal lines...
                                          08-17-2023, 11:09 AM
                                        • Scincidae
                                          UN70NU6900FXZA Won't Boot Unless I Temporarily Disconnect Right LVDS Ribbon
                                          by Scincidae
                                          I recently was given a UN70NU6900FXZA that would only boot loop once plugged in (auto powers on when plugged in). I found that disconnecting the lower (right side) LVDS ribbon, then plugging the TV in, followed by reconnecting the lower LVDS ribbon will allow the TV to work 100% normal as far as I can tell (no lines, no discoloration, no dimming or anything like that).
                                          I tried the tape method on the lower LVDS ribbon and found that if I cover pins 10 and 11 (counting from the bottom up) allows the TV to boot normal but 25% screen all the way to the right side is discolored. While...
                                          04-24-2022, 06:00 PM
                                        • kca
                                          50" LG tv with a slightly torn ribbon cable ~ Any repair method?
                                          by kca
                                          Hello all ~
                                          I have this LG 50" plasma tv that is in perfect working condition except for the fact that it has one (and only one), singular torn ribbon strip on one (and only one) of the 8 orange ribbon connectors that feed from the Y-Sustain to the screen itself.
                                          So, as a result, there is one, singular thin black horizontal line that goes across the entire screen. Distracting enough to render the picture unwatchable for all intents and purposes.
                                          What I am wondering is if anyone out there has ever had any success in fixing one of these ribbon cables...
                                          09-24-2020, 02:07 PM
