PLEASE HELP, Burnt off pad on Y-Main, how do I fix it
  • sergio2013
    • Mar 2013
    • 97
    I accidently used to much heat and burnt a pad on the board I don't know how to go about fixing it I heard that you have to scrape away the coating on the trace and if the capacitor legs reach you can solder it, but I scraped at the trace and no copper appears, only beside the trace some copper appears when I scrape, maybe that's not a trace im not sure. I included and circled in the picture the problem, a capacitor supposed to go there. please help
  • tw2005
    • Oct 2011
    • 6458
    Re: PLEASE HELP, Burnt off pad on Y-Main, how do I fix it
    It's a double sided board so from what i see there's no connection on that side. It'll be on the topside, how does that look? you may have to cut the leads a little longer so you can mount the cap high enough to get your tip in to solder.
    Be careful not to stress the top joint now as it'll be much easier to break it free without the cap anchored by the solder pad that's missing.
    • sergio2013
      • Mar 2013
      • 97
      Here is the top side
      • Sparkey55
        • Jan 2010
        • 1523
        Please do not double post the same question in the forum. You will recieve better help that way.
        • sergio2013
          • Mar 2013
          • 97
          I apologize sir. My mistake
          • sergio2013
            • Mar 2013
            • 97
            So are you saying I can just solder the caps negative and positive legs on the top side of the board instead of the back side?
            • tw2005
              • Oct 2011
              • 6458
              The bottom pad that's gone won't matter, the other pad on the bottom wil have to be soldered, but I can't tell now what was on the Top, almost looks like pads are ripped from there as well and brutally.
              usually on a double sided board the solder will also flow through the top as well when there's copper there.
              I was hoping it was just the bottom pad that lifted but I'm not sure what to suggest at the moment.
              If you can get a clearer higher res shot of the top maybe someone can work it out unless you know yourself what was there. Better put the board number up as well just in case someone has one and can have a look for you?
              • tw2005
                • Oct 2011
                • 6458
                I just had another look at the bottom, the + must be soldered on the topside pad, - on both sides. Maybe hold off and see if anyone else offers up some opinions to either confirm or dispute.
                Oh, and nice dust
                • sergio2013
                  • Mar 2013
                  • 97
                  On the top the pads are ok, it just looks that way cause I had to use a small screwdriver to feed in the hole cause the leg of the old cap broke off in there and I could not get it out with solder wick or a sucker, so the hole enlarged a bit, but there is still plenty of copper there.
                  • pk7tanner
                    • Apr 2013
                    • 98
                    My suggestion would be --> On the top side scrape away a little bit on the + side. It should look like cooper. If it does, cut your + lead so you can solder it to the board in a L (with a 1/4" gap between the board and the cap & about the same or less on the board). Solder the pos to the top and the - to the bottom. Or carefully solder the + to the lil black resistor in front of it.
                    But I'm not a pro, it's just what I'd try
                    • electomech-fixer
                      First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                      by electomech-fixer
                      I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                      I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                      09-15-2025, 01:42 AM
                    • chth96
                      Is it possible bridging tiny broken trace
                      by chth96
                      When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                      cutting tiny trace.
                      This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                      Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                      But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                      12-03-2022, 11:32 PM
                    • jshhh
                      Help repairing Yamaha RM1X synthesizer/groovebox - PCB trace for capacitor has been pulled off
                      by jshhh
                      Hi guys,
                      I've been trying to restore this Yamaha RM1X groove-box I bought, and the first thing on my agenda was to replace a bad capacitor that was making it so that the screen was super dim. As I'm a complete novice I went and accidentally pulled off one of the trace pads for the SMD capacitor as I was removing it, pulling up some of the green PCB with it. I've been trying to repair it by gluing down copper tape from where it began to pull off and solder the capacitor on after...atm I've just been attempting to do the same kind of thing on rubbish PCBs I got at a recycling place,...
                      03-26-2025, 07:05 PM
                    • dicky96
                      Zotac GTX 260 burnt component - can anyone identify?
                      by dicky96
                      Hi guys
                      This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
                      This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
                      Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
                      I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
                      The good phase...
                      12-01-2021, 01:02 PM
                    • swimllamaswim
                      Precision 5550 LA-J191P No Power, Burnt ISL9538
                      by swimllamaswim
                      I picked up this Precision 5550 to fix up recently, and found that the ISL9538 chip was burnt on pin 14 (CSIN). The two left side Type C ports negotiate at 20v, and the right side one only negotiates at 5v. I also found the EMI protection diode, DT35, was burnt on that side. I pulled the ISL9538 off, checked for any other obvious shorts, repaired the pad, and put a new one on. Now, I still do not get power, and there is a rapid clicking sound from somewhere on the board that I can't pinpoint.
                      Here are the voltages measured at that chip:
                      To note, DCIN at Pin 17 is low,...
                      09-21-2025, 12:26 PM
