Lg 42pc1d
  • kazzy
    • May 2013
    • 23
    • Scotland
    Lg 42pc1d
    Hi all i have got an LG 42PC1D that I have been having problems with for the past year and a half ish, The problem it's self started by the picture being distorted when the TV is first switched on, after a couple of minutes the picture restores it's self to full color. Now last week the TV stopped putting out any picture/really dark. I took the back off the TV and I noticed that 2 caps are swollen on the main power board. any idea's if this would be my problem as I'm a bit of a noob when it comes to TV diagnostics.
    Any help would be greatly appreciated.
    Cheers Greig
    Re: Lg 42pc1d
    It's a good idea to replace the capacitors if they are failed. While they may not cause the current issue, they give you a baseline to work from.
    Can we see a picture of the current fault... and any chance you took a photo of the fault it had previously?
    • kazzy
      • May 2013
      • 23
      • Scotland
      Re: Lg 42pc1d
      Unfortunately I didn't take a picture of it previously and I have replaced the capacitors this morning and plugged it all back in to no avail :/ just a black screen
        Re: Lg 42pc1d
        Really dark, so you can see an image, but it is faint?
        • kazzy
          • May 2013
          • 23
          • Scotland
          Re: Lg 42pc1d
          no nothing anymore tried menu and everything but nothing is visible :/
            Re: Lg 42pc1d
            Do you have a digital multimeter?
            • kazzy
              • May 2013
              • 23
              • Scotland
              Re: Lg 42pc1d
              yes a snap on one
                Re: Lg 42pc1d
                OK, let's see some pictures of the chassis layout then. Long time since I worked on one of these.
                • kazzy
                  • May 2013
                  • 23
                  • Scotland
                  Re: Lg 42pc1d
                    Re: Lg 42pc1d
                    OK, so in the middle of the chassis, you have the power board.
                    On the left, from your photo, you have the Y-sustain and Y-buffer.
                    On the right, you have the Z-sustain.
                    Can you get a close up shot of the power leads going to the Y-sustain from the power supply?
                    • kazzy
                      • May 2013
                      • 23
                      • Scotland
                      Re: Lg 42pc1d
                      Power Board side of the cables
                        Re: Lg 42pc1d
                        So, get your meter out, set it on the HIGHEST volt DC scale, probe one of the pins marked V-S (red probe on the pin, black probe on the chassis) and report the reading. Note, the connection to the Y-SUS and Z-SUS must be left in place.
                        • kazzy
                          • May 2013
                          • 23
                          • Scotland
                          Re: Lg 42pc1d
                          will i plug it in and switch it on?
                          • kazzy
                            • May 2013
                            • 23
                            • Scotland
                            Re: Lg 42pc1d
                            189V on both terminals with tv powered on
                            • JonathanAnon
                              • Jul 2012
                              • 457
                              • Ireland
                              Re: Lg 42pc1d
                              What values are printed on the back of the panel.. ?
                                Re: Lg 42pc1d
                                189V is fine for this generation of PDP.
                                • kazzy
                                  • May 2013
                                  • 23
                                  • Scotland
                                  Re: Lg 42pc1d
                                  any ideas of what I could do now? :/
                                    Re: Lg 42pc1d
                                    You have two fuses on each board, right? See what voltage you get on each end of each fuse.
                                    • kazzy
                                      • May 2013
                                      • 23
                                      • Scotland
                                      Re: Lg 42pc1d
                                      one fuse on each board reads 190V the other reads 60v on each board.
                                        Re: Lg 42pc1d
                                        Both ends?
                                        • ChattFix
                                          Samsung UN55TU700DFXZA Distorted Picture
                                          by ChattFix
                                          I have a Samsung UN55TU700DFXZA with a distorted picture and I thought it was a bad panel. I had a similar board with one number off and still tried it to see what the issue could be. The picture came out clear with only missing blue hue I think. I found a replacement board for $30 but wanted to learn if this would be the main IC or possibly something else. I don't have service manual so looking to learn about these cheap sets....
                                          06-02-2024, 03:50 PM
                                        • ktmmotocross
                                          Apple a 1708 - 820-00840 - distorted picture
                                          by ktmmotocross
                                          hello.
                                          Have this Apple a 1708 - 820-00840 that have distorted picture for few seconds, than come to normal or few seconds and than again distorted picture. flexing hinges have no effect. distortion is like thin horizontal stripes and bad picture...
                                          02-13-2022, 05:20 AM
                                        • Ven
                                          SONY KDL-48WD653 - Distorted Picture, Can you help by photos?
                                          by Ven
                                          Can you help me please what can be wrong with this distorted picture?
                                          Thank you....
                                          09-17-2023, 06:13 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Nicktronic
                                          RCA RWOSU7047 Distorted picture
                                          by Nicktronic
                                          Hey, please the attached pics. This TV will turn on (Backlights on) but no picture provided. I tried disconnecting the right side LVDS cable between the tcon and buffer board (pic 1) and then the left side LVDS cable between the tcon and buffer board (pic 2). I get an image each time, but as you can see, there's a discoloration issue happening. But with both LVDS cables connected i get a black screen (BL ON though).
                                          Just curious if anybody has seen this before? I will provide pictures of the boards shortly, I'm just in a rush and wanted to get this posted and see what the experts...
                                          04-23-2023, 04:40 PM
