Replacing a bad cap on TV
    Re: Replacing a bad cap on TV
    Without seeing a video of the problem that exactly represents what you are getting it's really hard for me to suggest whether it is a panel or main board fault.
    • justjoe
      • May 2013
      • 35
      • England
      #42
      ok i will leave it off for a couple of days and see if i can get a picture again, thanks Tom.
      • justjoe
        • May 2013
        • 35
        • England
        #43
        just noticed that this screen panel board seem to be missing some of those spongy pressure pads, the pic shows where 1 is missing, and each end of the board has no pressure pads but has similar gold paint as if they should have some.
        These pads have not fallen off and been lost by me, i just know that they are either missing from the factory or its designed this way so i could try making my own pad for it.
        I
          Looks like there's a screw hole there, so there wouldn't be a pad there anyway.
          The pads aren't for pressing on the tabs or holding the board in place. They are there simply to reduce the interference that driving the panel produces by completing the shield around the panel.
          • justjoe
            • May 2013
            • 35
            • England
            #45
            you're right i see the metal surround has bulges where the pads go now.
            ive just managed to get a video recording of the problem, i will update this post with it soon.
            • justjoe
              • May 2013
              • 35
              • England
              #46
              Heres the video, you dont see much but the word "scart" appears in the bottom left corner.
              If I had left it unplugged for another 12 hours or more the picture would have stayed on for a few seconds longer, in fact if i unplug it for 1 week the picture is ok for about 30 seconds then it fades away.
              http://www.youtube.com/watch?v=sv-R_...ature=youtu.be
              My noob guess is that it seems like something is overheating, or a cap is bad but it will run for a few seconds when very cold.
                That is an odd one -- I haven't seen that before. Is there any chance you could get it playing sound then try to show a video.. need to see if the video freezes before it fades or not (if it's freezing it might be a T-con problem.) And the backlight is full brightness all the time through this. Very strange.
                • justjoe
                  • May 2013
                  • 35
                  • England
                  #48
                  I can get sound but no picture, before i get to the channel any kind of picture has come and gone already, unless i unplug it for a week.
                  Also its not freezing the video, i remember that i was able to scroll the menu while it was fading away.
                  yes backlight is very bright but you cant see it in the video.
                    Maybe it's time to get a can of freeze spray. Poundland nearby me have them for a quid for 200ml.
                    You can spray the freeze spray around the panel and locate the temperature sensitive part.
                    • justjoe
                      • May 2013
                      • 35
                      • England
                      #50
                      I'll look into it thanks. Im thinking the problem is somewhere between the cable to th e screen form the mobo or something on the mobo itself, worth replacing the mobo if i find one, i saw a power supply board for only £25 on ebay, but out of interest id love to know what the problem is on the board.
                        I would doubt it myself that it is the motherboard, the symptoms do not match up. But that's part of the diagnosis process. The motherboard in your TV is used in about fifty million different TVs. I've seen it in baby 19" and 24" as well. Go by the part numbers written on it, not the model of your TV.
                        • justjoe
                          • May 2013
                          • 35
                          • England
                          #52
                          of course yea i forgot about that, i heard that somewhere, thanks, i just hope its not the screen.
                          • justjoe
                            • May 2013
                            • 35
                            • England
                            #53
                            You are not gonna believe this but the TV is now working ok, i turned it on to try to capture more footage of it fading but its working ok, im sure this wont last though.
                            edit: this is so annoying, it obviously isnt fixed but seems to be working ok.
                            since it didnt work yesterday i haven't touched it, only pulled the plug out, so it cant be a loose connection.
                            im going to post a video showing the tv now working, at least then you can see it does work at times.
                              A fault that goes away by itself can just as easily come back by itself; though, it may have been a loose cable, I would be surprised.
                              • justjoe
                                • May 2013
                                • 35
                                • England
                                #55
                                Ok heres the video of it working, not much help i know but proves im not imagining things lol
                                In the video I turned the brightness and contrast up in the hope it would overload whatever is faulty, just a noob test.
                                http://www.youtube.com/watch?v=BbLmd...ature=youtu.be
                                ive been playing a movie via USB drive for past 10 minutes and so far its working ok so far, i guess when i screw it back together it will go faulty again.
                                • justjoe
                                  • May 2013
                                  • 35
                                  • England
                                  #56
                                  Well hopefully this is my last post on this, it seems like playing around with the ribbon you spoke about has fixed it, im getting a slight screen flash though, its like when you videotape a computer monitor and on playback you get those dark bands flashing because the frame rates are different, well its like that but very slight, but it only does it when the TV has been screwed back together, so theres clearly some kind of ill fitting part, even though everything is exactly the same, screws all the same torque, no bent plastic or metal anywhere, no trapped wires etc, lcd flats seem to be so temperamental.
                                  I hope this thread might help others because ive learned a lot of important stuff from you guys, thanks for your time and patience.
                                    I'd only put four screws in it (four corners) for now, it may go wrong again and you may need to apply a more permanent shim.
                                    • justjoe
                                      • May 2013
                                      • 35
                                      • England
                                      #58
                                      Yea thats what ive done but im going to be playing with it more yet to cure this new dark band problem, the fact i got rid of it shows both problems ive had is down to bad connection/contact. Gonna brainstorm it and see if I can spot a design flaw or something, but im happy to fix the main problem.
                                        It uses a crappy cheap Chimei Opto (Innolux) panel, they have lots of tab bond problems.
                                        • justjoe
                                          • May 2013
                                          • 35
                                          • England
                                          #60
                                          Well since I took those pics of the tabs its been working again, but the pressure on that panel doesn't seem to make any difference to the picture on mine, i cant reproduce the fade out and cant get rid of this flickering, its not usable cos its too distracting even though its very slight.
                                          • BigPete
                                            Panasonic Heatpump Dryer Repair
                                            by BigPete
                                            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                            Unfortunately the whole machine has to come apart to fix it.
                                            I have...
                                            11-01-2025, 06:40 PM
                                          • AquaMan Ua
                                            by AquaMan Ua
                                            05-17-2025, 09:40 AM
                                          • Alfieh
                                            NAD C320BEE repair possibly bad capacitors
                                            by Alfieh
                                            hey Im very new to repairing electronics with capacitors as well as using a multimeter so I need so help/guidance fixing this issue
                                            recently I was handed a family members old NAD C320BEE that they had in their loft for storage for a few years but when powered on it went into power safety mode due to a problem on the protection circuit somewhere before it went into storage I was told it worked fine I found lots of people online talking about how the capasitors are known to be pretty bad in this model and can cause this issue the only problem being I don't have much experience sorting...
                                            11-19-2024, 04:55 PM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                            11-20-2024, 08:52 PM
                                          • yuzupatogik
                                            Help with replacing Capacitors on Altec Lansing ATP 3
                                            by yuzupatogik
                                            I have this old (2004?) Altec Lansing ATP3 and i would like to replace the capacitors. I have identified 34 out of the 36 of them as Samxon GR of various capacities and voltages.
                                            I can't find datasheets for the Samxon in any of the following variants:
                                            10000uF 25 v - this one i really want to replace because i suspect it is what causes a dull hum regardless of the volume knob position or if the source is plugged in. I am eyeballing the Rubycon 25PK10000MEFCGC18X35.5 for this purpose. So if i pay a 10x the price part for shipping i might as well go ahead and...
                                            02-14-2025, 04:11 PM
