Vizio 321Vl No HDMI
  • truep
    • Aug 2010
    • 373
    Vizio 321Vl No HDMI
    This set works fine on all other inputs including antenna, but neither HDMI port works. I get a no signal message on the screen.
    The blu ray player and cable work fine on another set. Any suggestions?
    Re: Vizio 321Vl No HDMI
    Surge or ESD damage to the HDMI receiver IC. Usually needs a new main board -- IC rarely commercially available.
    • ecking767
      • Oct 2009
      • 492
      There is a HDMI chip p/n: PI3HDMI301ZLE, check for any burn marks. If you have expert soldering skills you can replace that chip. its a SMD chip.
      A magnify glass will be helpful to examine the PI3HDMI301ZLE
      http://www.ernestos-electronics.com/...-hdmi-ic-chip/
        I'd be surprised if you can buy that IC…
        • eklunge
          • Feb 2012
          • 5
          • hong kong
          I also have the similiar symptom for the JVC Lt42FX77. The set is fine for the other input but not for the HIDI input. The first symptom is black screen with sound. After replace the inverter board, the picture appeared with sound but not for the HDMI input. Enter in service mode, it found that the Analoge board has problem. I try to find the analog board through e-bay but can not find one. As Tom66 said it is not easy to find the IC. I think I need to return the set to client.
          • truep
            • Aug 2010
            • 373
            I found a new main board and should receive it later in the week.
            • edugimeno
              TD Systems K50DLP8F works fine on 1 HDMI, bad on others
              by edugimeno
              I have this TV set that I spent a long time fixing it.
              I finally found a shorted SMD capacitor near the plug from the PS at the main board. It was shorting one of the main voltages (can't remember which one)
              I removed that capacitor, and as it has another one in parallel, I left it with only one, checked it and it seemed to work fine. The solder near that capacitor was really delicate as I pulled apart one trace so I prefered to not mess much with it after I had to air solder one small thread of copper
              I didn't use that TV much at that time. Now that I'm using it,...
              10-06-2023, 03:00 PM
            • amuse619
              Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
              by amuse619
              Hello!
              Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
              Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
              08-14-2024, 01:22 PM
            • CapLeaker
              Dell ATX PSU won’t start, but forcing it works fine?
              by CapLeaker
              Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
              Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
              10-28-2024, 06:59 PM
            • kamiewtype
              MPG Z590 No display output with known working GTX 1060/RTX 3070, works fine with GTX 1030
              by kamiewtype
              I have a customer machine on my bench right now that's stumped all the techs, so I decided to come here for help.
              The specs are:
              MPG Z590 Gaming Carbon Wi-Fi (MS-7D06)
              Intel core i9-10900kf
              2x16gb Corsair Vengeance kit
              BIOS ver is E7D06IMS.1B0, from 6/12/2023
              The machine was brought in because it would not POST after a GPU upgrade from a GTX 1030 to an RTX 3070. The customer also brought in the original GTX 1030, as well as a GTX 1060 that the machine also wouldn't POST with.
              I tested the 1060 and 3070 on my bench (ASRock X570 Phantom Gaming...
              11-01-2024, 10:52 AM
            • huzo
              Dell 5590 no image on LCD,HDMI works ,the board works...
              by huzo
              The board is LA-F411P ,DELL 5590 ...
              The screen polarises,no backlight,no image,only black screen,tried another screen,the same,so there is no backlight,but there should be an image when i shine a lamp behind the screen,but there is none...only dark screen...when screen is connected and i press F8 to turn the image over to the external monitor, the external monitor gets coloured bars ,but when i disconnect the cable from the EDP ,the HDMI picture is good...What could be the problem? I don't have another edp cable, but i measured it with meter and it comes out good...i am baffled......
              02-16-2025, 03:08 PM
