Sharp LC-42D62U Inverter board
    Re: Sharp LC-42D62U Inverter board
    I do not use anything less than 40 Watts Iron.
    • FlipTV
      • Apr 2013
      • 46
      Ok good to know. I was looking to buy a 60 watt iron possibly one that is adjustable.
      If yiu go too high on the wattage, could it damage the board?
        You use in 60 Watts mode when you work on piece of work that has lots of mass that will cause the temp to drop due heat sinking effect. You will develop your skill when you solder lots of works.
        • FlipTV
          • Apr 2013
          • 46
          Ahh, okay. So the wattage used depends on the mass of the object you are working on.
          If I buy an adjustable 60 watt iron, and am bout to solder the fuse I should lower the wattage to around 25-30
            Set it too about 40 Watts, what happen when you set to low wattage is that you will be heating the circuit traces for a long time due to heat sinking of the solder tip and you will end up lifting the traces. You should practice on junk board and try using different setting to see what happen. It is the real hands on learning.
            • cashkennedy
              • Aug 2011
              • 668
              If you buy a soldering station it will have a temperature selection , If the part your desoldering has a lot of metal / is attached to a thick metal section of the board, youll have to turn the heat up higher then youd normally solder at. Leaded solder also melts at a much lower temp the lead-free, so when soldering you might adjust your temperature up 50 or 100 degree Celsius based on what you run into.
              Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
              • retiredcaps
                • Apr 2010
                • 9271
                #47
                Originally posted by FlipTV
                So when I put the MM into continuity mode, touch the 2 ends of the fuse, should it beep if it is good??
                It helps if you think of continuity (beeping) not in terms of good or bad, but as a tool that shows resistance readings of 25 ohms or less.
                As I wrote before, a good fuse measures less than 1.0 ohm. Your Fluke 12 will beep.
                A fuse that measures 20 ohms is bad and your Fluke 12 will beep.
                --- begin sig file ---
                --- end sig file ---
                • FlipTV
                  • Apr 2013
                  • 46
                  Thanks everyone for all the helpful information.
                  • FlipTV
                    • Apr 2013
                    • 46
                    So i replaced the fuse and the fuse gets 24v on both sides. I tested the 2 white fuses below and they are getting 24 volts as well.
                    II am now getting 2 seconds to black.
                    When I test the voltage on the test points near the transformer, it reads. 03 volts.
                    The slave board acts the same way as the master.
                    I'm banging my head on the wall now lol.
                    Please help
                    • FlipTV
                      • Apr 2013
                      • 46
                      Also, when I take the reading of the rest point on the inverter when powering on the tv it reads 12 v then goes to. . 03 volts.
                        So are you using the old boards and you also seat all the lamp connectors, clean the burnt connector real well? If one of the lamp does not turn on or will not fire up, or not connected or stays conducting, it will also shutdown the inverter.
                        • FlipTV
                          • Apr 2013
                          • 46
                          I did buy a new slave inverter originally due to the burnt mark i saw. It does it with both the new and old slave inverter.
                          Can I clean the connectors using rubbing alcohol?
                          Also what could explain the. 03 voltage reading I am getting now?
                          Prior the the fuse install it was getting 24 volts
                            Can you show me that test point in the picture? This thread is getting long and hard to keep track now.
                            • FlipTV
                              • Apr 2013
                              • 46
                              Here you go.
                                OK, I see the picture of the transformers but I do not see the marking where the test point is. Is it right on the leg of the transformer?
                                • FlipTV
                                  • Apr 2013
                                  • 46
                                  Right next to c326 and below it.
                                  Prior the to the fuse install, it read 24v
                                  Think I might have a cold solder on the fuse?
                                    OK, you were looking directly at the primary side of the transformer, which when the MOSFETs that are driving the transformers are not on yet when in TV in standby mode which you should see 24V on the transformer pins, when the inverter circuits start driving transformer by pulsing the DC with real high frequency, then you will need meter that can read AC (the voltage at the transformer pins are no longer at steady, but pulsing) at very high frequency it can be as high as 80,000 Hz, which your meter can not response that fast. When the lamps flash on and do the 2-second to black, one it is black out, that 24V should be there again, unless the inverter board tells the main board to shutdown the 24V power supply.
                                    • FlipTV
                                      • Apr 2013
                                      • 46
                                      Here's the thing, I no longer get 24 volt reading on the test point in the pic I attached above.
                                      Thinking it was a bad solder job, I removed the fuse and tested the test point and received 24volts
                                      Resolder the fuse and got. 03 volt on the test point.
                                      So there is a line of caps going down the center and one side when you take readings is 24 v the other side is. 03
                                      Is there something faulty going on which is causing the voltage to go from 24 to 03v as soon as it crossed the line of caps?
                                        But that blown fuse is for the PWM IC which drive the MOSFETs that drive the transformers, the white fuses are the one that supply the 24V to the primary winding of the transformer. You can verify by measuring the resistance between the white fuse and the primary side winding of the transformer. Beside you did not have the backlights on at all before replacing that black fuse. omething has to short out real bad to drop the 24V power supply, which if that is the case, the white fuses should have blown.
                                        Just to be sure, what do you get at point 1 and point 2?
                                        At this point the inverter is sensing something to cause it to go into shutdown.
                                        • FlipTV
                                          • Apr 2013
                                          • 46
                                          What would you suggest to be the next thing to troubleshoot on the inverter?
                                          II have a whole new respect for people in the electrical field.
                                          I work in IT and man this is such a learning curve.
                                          It's very intriguing though.
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • lostone
                                            Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                            by lostone
                                            Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                            First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                            When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                            05-19-2024, 11:40 AM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
