Rca l42wd22 audio problems
+ More Options
Posts
  • xredhawk
    • Jul 2011
    • 103
    Hello, im hoping to find somebody who has solved audio problems on this lcd tv,audio comes on for awhile ,then goes out after 10 mins very distorted sounding when on, any help would be appreciated!
    Re: Rca l42wd22 audio problems
    If you hook up the powered speakers to the Auido line level output RCA RED/WHITE jacks, do you get the distorted sound there also? We need to find out if the problem is in the sound processing/ preamp/ or power amp section.
    • xredhawk
      • Jul 2011
      • 103
      ok ill have to go to the radio shack and get a adapter to try , thanks ,ill repost back soon
      • xredhawk
        • Jul 2011
        • 103
        i get nothing out of rca jacks, i get sound thru head phone jack but it goes out after 5 minutes , i power off the tv it comes back on then goes out after a minute,sound is better but still a hissing sound
          Would you say it's very similar to what comes out of the speakers? It sounds like either power supply bad (low voltage to audio processor, possibly main board voltage regulator fault) or bad audio processor IC.
          • xredhawk
            • Jul 2011
            • 103
            its weird i go into rca sound menu to set maxium volume , menu says to hold the ok button to test maxium volume and amp kicks in and internal speakers work, seems like sound gets better as tv warms or i power on and off tv ,
            • xredhawk
              • Jul 2011
              • 103
              i had a bad cap on the psu , im thinking i have more that needs testing.
                The bad cap could easily cause that. Have you checked the supply voltages coming from the PSU? e.g. a low or unstable 5V or 12V might cause this.
                • xredhawk
                  • Jul 2011
                  • 103
                  im getting 11.89 volts going into the audio amp
                    Have you checked other power supply voltages too, like 5V and 24V?
                    • xredhawk
                      • Jul 2011
                      • 103
                      i just saw this fix with the same symptoms,
                      • xredhawk
                        • Jul 2011
                        • 103
                        this tv has been in the shop before when first bought about 3 yrs ago, fuse mod has already been done
                        • xredhawk
                          • Jul 2011
                          • 103
                          i bought set off guy at worked that told me it was put in the shop shortly after he bought set
                          • xredhawk
                            • Jul 2011
                            • 103
                            maybe cold solder joint to bottom fuse?
                              Perhaps new fuse has failed again?
                              • xredhawk
                                • Jul 2011
                                • 103
                                top fuse reads good , repair man that did mod , put too much solder on top, cant tell if he got it good on bottom.
                                • xredhawk
                                  • Jul 2011
                                  • 103
                                  thanks tom! tv working good now
                                  • dozer69
                                    • Feb 2016
                                    • 8
                                    • united states
                                    my RCA L42WD22 is doing the same thing. what did you do to fix it
                                    • dozer69
                                      • Feb 2016
                                      • 8
                                      • united states
                                      my sound comes on for a few minutes but goes out. if you turn the tv off it comes back on for a few minutes
                                      • samson7point1@yahoo.com
                                        Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                        by samson7point1@yahoo.com
                                        The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                        The player processes the audio signal using two different reference frequencies. The "R"...
                                        04-30-2024, 11:22 AM
                                      • ajvpb
                                        Denon 3313CI Distorted Audio FL+FR
                                        by ajvpb
                                        Hobbyist repairman here so I've reached the end of my troubleshooting abilities. The audio out of the FL+FR speakers is very distorted and almost unintelligible. BUT! That only applies to digital audio; Analog plays through just fine. The distortion carries to headphones if those are plugged in with audio from a digital source. All other speaker channels play fine regardless of digital or analog.
                                        Previous experience with similar distorted audio has been bad resistors on the amp output - Could bad smd resistors on the hdmi board cause the same problem? My understanding...
                                        02-22-2023, 05:21 PM
                                      • NanoTesting
                                        Anyone else been having problems with chinese laptops using ESSX8336 / ES8336 audio?
                                        by NanoTesting
                                        This audio chipset has been a pain to deal with, most of the time its impossible to find drivers for chinese laptops that have no name/brand, or generic rebranded laptops.
                                        Huawei also started to use it BUT they no longer host drivers on their website since they want you to force their PC manager app that often refuses to install after bios flashing and apparently the generic drivers around wont work on some intel systems and others wont work on amd systems, the generic ones have worked only once and i think i have had this problem on 30+ laptops so far in the last year.
                                        02-21-2025, 12:33 AM
                                      • Aimbit
                                        Diagnosing Sega CD 2
                                        by Aimbit
                                        Hey all,
                                        Hopefully someone here knows about β€œvintage” game systems.
                                        I have a Sega CD and it runs perfectly fine except for two specific things I've seen so far.
                                        1. The boot menu music is distorted, that is the jingle that plays on the loading screen with no disc inserted. It seems that is it specifically the bass line of the jingle. It is fully distorted/scratchy sounding.
                                        2. I've only come across this issue in Spider-Man so far. During any cutscene when dialogue is playing, the audio will intermittently skip, the same way every time....
                                        10-21-2023, 07:36 AM
                                      • ChaosLegionnaire
                                        by ChaosLegionnaire
                                        09-13-2022, 09:02 AM
