Vizio vp50 hdtv20a no pic just sound
    Re: Vizio vp50 hdtv20a no pic just sound
    But leave everything else hooked up?
      Yes, I'd leave everything else connected.
      LG Plasma Mal-Discharge Correction Service
        VS volts 209.5
        VG volts 15.05
          VS volts 209.5
          VG volts 15.05
          How about VA?
            I also was checking the fuses for power and were the main power wires come in there are two fuses one on each side of the plug. The one on the right has 122.7 ac volts and the one on the left has .708 ac volts is that normal or should both have 120 volts?
              I believe that's normal. We still need to confirm your VA voltage.
                Sorry just found the VA 63.9 volts
                I had to unplug the buffer board plug that's the only VA pin I see
                  So, it seems that the Y-main and X-main are the only faulty parts. I'd test the components in circuit with the failed caps (mosfets, diodes, resistors, etc) on those two boards then replace as needed. Do you have any other pics from a different angle that show the components on the heat sinks?
                    Ok thank you for your help. Is there any website I can go to for more info on how to check the two boards?
                      I haven't looked around here much, but there may be info on how to do component-level testing. Hopefully, you just have blown caps. The other thing I was thinking is that you should probably remove your buffers and test them for shorts to make sure they're not bad. Sometimes, the pin holes are so small that they're hard to see. Tom66 has some good info on how to test this particular set of buffers @ 4:35 in this video: http://www.youtube.com/watch?v=51SZsfH60EY
                        Give me a min and I will get them to you
                          This is the y-main
                            Same side y-main
                              Other side of y-main, see the bad cap.
                                Y-main
                                  X-main
                                    X-main here is the other bad cap, between the fuse and the bigger 250v 68uf cap. I already took it out waiting on the new one. Luckily I ordered two one for a spare, then I found the other one blown on the y-main tonight.
                                      Did you check the green fuse next to the cap? I'd also check the transistors on that heat sink.
                                      Yeah, I always order extras. I'd do the same thing on the X-main: Check the components near the cap and check the transistors on the heat sink. It looks like there's a green fuse near that cap, too.
                                        I checked all the green fuses, and they are good. Don't know how to check the transistors.
                                          It's hard to see the markings on the transistors, but I can at least see K2837, which is an N-channel mosfet. I'm guessing that the others are N-channel transistors or diodes, but I don't know.
                                          For K2837, from left to right, you have Gate, Drain, and Source pins. In diode mode on your meter:
                                          (1) Place your red probe on Drain and black probe on Source: Should read "OL" or "1" depending on your meter (no reading).
                                          (2) Reverse your probes: You should get something like 0.5V.
                                          Repeat this test for Gate and Drain:
                                          (1) Place your red probe on Gate and black probe on Drain: You should get something like 2V. <<- may be dependent on your meter.
                                          (2) Reverse your probes: Should read "OL" or "1" depending on your meter (no reading).
                                          The key is that you should get a reading in one direction and no reading in the other direction.
