Vizio Vizio VT420M Good Backlight no sound no picture
  • a_eclipse_guy
    • Apr 2013
    • 8
    Ok, I have spent a few days reading posts about this TV.
    It seems as if they are junk..
    Long story short here is the prob.
    Turn power on at the switch (no remote) The "Vizio" logo on the frame turns a faint amber color and fades out. The backlight come on and then off for a sec and back on and stays on. There isn't any display at all.
    Not sure what the board is called that sends signals to the screen was swapped out with no change.
    I have checked the power supply everything seems to check out. Voltages going in and out of it (all caps look good) etc..
    I did check voltages at the reg (U702) Counted pins with the tab up and counted left to right.
    Pin 1 0.00 volts
    Pin 2 3.297
    Pin 3 5.12
    Are these correct voltages?
    Before I spend any cash on this tv I would like to know how to check to see if the screen is ok before I replace boards etc etc etc..
    Kenneth
    Re: Vizio Vizio VT420M Good Backlight no sound no picture
    That is correct, it is 3.3V regulator. I expect the board to have more than one regulator.
    Do you get either 5 or 12v at the T-CON fuse?
    • a_eclipse_guy
      • Apr 2013
      • 8
      Yes, I do have 12V at the T-CON fuse.
      The power will also drop to 0.0 and back to 12 with the on/off thing the backlight does...
      There is one other reg that I found on the board (u701)it is missing pin#2 on it.
      Pin#1 11.28
      Pin#2 Stub 0.00
      Pin#3 9.07
      Only 2 regs that I see on that board.
      If it matters this board is different than any of the other ones I have seen on any site so far.
      I was thinking it might be the board. However, I read somewhere where someone said to disconnect the cables from the T-con board and watch the screen for changes. Tried and the screen doesn't change at all.
        That may be 9V regulator. Do you have the number as printed on it. At this point you will need the new main board.
        • a_eclipse_guy
          • Apr 2013
          • 8
          It has 17809 printed on it.
            OK, that is the same as LM7809, positive 9V regulator.
            • a_eclipse_guy
              • Apr 2013
              • 8
              So I guess I am looking at a board......
              What are the odds that it could be a prob with the screen its self?
              I don't really want to drop 200.00 for a new one.
              Would it be more cost effective to have it repaired?
              • retiredcaps
                • Apr 2010
                • 9271
                Sometimes, the main board has components on the backside.
                --- begin sig file ---
                --- end sig file ---
                • a_eclipse_guy
                  • Apr 2013
                  • 8
                  I didn't find anymore on the board. Does anyone know of a way to test the panel(screen) to find out if it is good or not?
                  • JonathanAnon
                    • Jul 2012
                    • 457
                    • Ireland
                    Maybe a video or pictures of this would be helpful..
                    • a_eclipse_guy
                      • Apr 2013
                      • 8
                      I did find one more reg on the back of the board.
                      Pin1 .008
                      Pin2 Stub 5.00
                      Pin3 9.03
                      I guess it is working correctly.
                      • Cosmo66
                        • Nov 2012
                        • 87
                        I'm dealing with this same model, exact same issue. It seems to be a common problem with this model, as I've noticed on other threads
                        Backlights come on, power supply voltages are all good. Already changed T-CON. No signal, audio or video. Sometimes it stays on. Sometimes shuts off.
                        I'm thinking this is an eeprom issue.
                        The strange thing is that I've removed and reinstalled the main board a few times to resolder joints. Everytime I do this the TV will work afterwards, I'll think I fixed it until later when I go back and turn it on, the problem returns.
                        To get it working again, I have to unplug all connectors on the main board, wait a while, and will work for a while again. I've tried to just play with the connectors, thinking one of them is bad or loose, but this never changes anything. I have to actually remove the connectors for a while. I know this sounds ridiculous to anyone with any actual electronics knowledge
                        I'm thinking maaaaybe one of the caps on the psu is holding some voltage to the main board, possibly keeping the jacked-up eeprom in some weird state......??/?
                        I don't know I guess the only way to find out is replace the eeprom. I'll report back to this thread after I change it.
                        • a_eclipse_guy
                          • Apr 2013
                          • 8
                          So I have been bored and started playing around with this TV again..
                          I unplugged the LDVS cable from one side and that side of the screen turns white. Same with the other side. So would I be looking at the Tcon or a mainboard.
                          One thing I did was hookup audio to the set and switched the menu button to scroll through inputs. Didn't work...
                          • philliesfan30m
                            • Aug 2013
                            • 542
                            as budm stated earlier in the post that you would need a new main board i would say he is right because he is right more often than not about what to replace on tv's. and if you already changed the t-con to no avail then that is the only other board to replace that could possibly fix the problem you are having.
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • ggil44
                              Vizio M65-E0 No Picture, No Sound
                              by ggil44
                              Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                              09-03-2024, 08:30 PM
                            • TR103
                              by TR103
                              - it keeps rebooting
                              01-22-2025, 04:12 PM
                            • jord4231
                              Toshiba 37AV500A Regza TV good power supply no sound no picture
                              by jord4231
                              Hi Everyone,
                              I'm working on a Toshiba 37AV500A Regza TV.
                              The issue:
                              TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
                              The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
                              I checked the PSU voltages and everything looked good.
                              No bulging caps or signs of heat.
                              24v aud = 24.41v
                              12v = 11.98v
                              5v = 5.062
                              p_o/f = Goes high...
                              03-29-2022, 09:21 PM
