Help a veteran please
  • Coinhunter
    • Oct 2011
    • 65
    Help please. I am working on a Iraq/Iran veteran's TV who returned 80% disabled and is suffering from PTSD. They cannot afford a new TV and I don't have an LCD that I can do a simple repair and give them at this time.
    Here is the problem. The TV will turn on, I can scroll through the menu, select input, view the volume bar etc. but there is no picture or sound. This is a projection style Hitachi Model 57F59A and yes it is 7 years old but up until a few days ago it worked flawlessly. I have checked the power supply board and the video input boards for visible signs of problems such as bulging caps or burned spots, fried resistors and blown fuses but nothing simple pops out at me. Any help will be appreciated. Thanks and God Bless.
  • Jack Crow
    It's a CLASOB!
    • May 2008
    • 823
    Re: Help a veteran please
    C,
    I have two working CRT types I would be happy to donate.
    But they are not cheap to ship from Virginia.
    If you now someone traveling from the area of our nations capitol, I would be happy to sync up and hand them over.
    Military guys kept me alive in Iraq, this is the least I can do in return.
    As for fixing the one you have, perhaps one of the guys here can come through.
    TV's are not my strong point. More of a two way radio geek.
    Ping me back here if you want the sets.
    Jack Crow
    "You are, what you do, when it counts"
    The Masso
    "Gravity, the quickest way down"
    Mayor John Almafi
    "You ever drop an egg, and on the floor you see it break?
    You go and get a mop so you can clean up your mistake.
    But did you ever stop to ponder why we know it's true?
    If you drop a broken egg you will not get an egg that's new?"
    MC Hawking
    • Coinhunter
      • Oct 2011
      • 65
      PM sent, thanks for the offer.
      • Coinhunter
        • Oct 2011
        • 65
        By the way it is a DP65g chassis and I have the service manual trying to follow the troubleshooting flow sheet now.
        • MisterD
          • Oct 2012
          • 668
          You say you can scroll through the menu, select input, view the volume bar etc. but there is no picture or sound. That sounds to me like it's not set to the correct input or source, is it hooked to a cable signal? with or without cable box? when set to TV it may need to be on channel 3 or 4 when using a cable box, try a Dvd player hooked to AV Jacks and select AV in the Menu.
          • harp
            simple win network with optimization issue
            by harp
            simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
            06-23-2025, 11:01 AM
          • harp
            simple DIY voltage monitor
            by harp
            I am designing a simple circuit that can catch a narrow glitch in voltage fluctation, and presented in visual/audio way, with as little as posible common type components. The circuit is done on test board and work like I wish. I post schematics here and like to hear a voice of educated electrician, hopefully to insight of some flaw or better design. Thank you ...
            09-02-2025, 01:20 PM
          • Nevillet
            Simple PIR sensor circuit to drive a small motor
            by Nevillet
            Hi All,
            I'd like some help designing a simple circuit for driving a small DC motor.
            The PIR module is a HC-SR501 which runs on 6V supply and outputs 2.4V when triggered. (Datasheet attached)
            I'm not totally sure which motor I need yet but lets assume it'll be 12V and draw a maximum of 100mA.
            Can somebody design me a simple circuit for me using something like a 2N3904?
            I'm happy to include a relay if that makes sense.
            Many thanks.
            https://www.badcaps.net/forum/attachment.php?attachmentid=3...
            07-09-2023, 10:48 AM
          • Davi.p
            Simple question about sodimm modules
            by Davi.p
            Hello, i wish to find a way to identify ram module by only the socket type, sometimes i go to the local eco isle and happens to catch someone that is throwing his laptop, but usually it has no memories, i get it but i have no parts to test all them, thanks.. bye
            ps: searched online, no info..
            10-10-2025, 03:40 AM
          • harp
            simple 24v fan control problem
            by harp
            I am working on automated fan speed for lab psu... the fan is 24v 0.15A, and I am connected it to 820 ohm to ground, that provide minimum silent air flow on startup. It is powered around 4v at minimum point. Parallel to resistor I connected BD139, that drive a 10k NTC. Everything work like expected, but in extended test, where I isolate NTC, I have few issues, and like to ask here for help. 1. If ntc is not connected to heatsink, it go slowly to heat up and up and fan make noise than... At point "A" I measure voltage and put NTC in flame, everything is working ok till about 1.1v, and...
            10-09-2025, 03:20 PM
