I am visiting my great grandfather and his Sony has a a yellow sploch that covers most of the screen and a thin red bar across the top of the screen. This is a rear projection/DLP tv and he has already had the lamp replaced.
sony kdf-46e2000 problem
I have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
Service Menu/Factory Reset Codes for TVs
http://www.badcaps.net/forum/showthread.php?t=24809Tags: None -
Re: sony kdf-46e2000 problem
If I were to find another DLP at the dump would parts be interchangeableI have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
These are notorious for this type problem.
Good luck! =PComment
Is there a way to rig fix the light engineI have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
by ChrissygizmoHello again everyone,
This is my latest mission, to try getting this Sony tv back to normal working order…
I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried... -
by crackedprintI have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
I have tried a Cold Reset as per the service manual.
I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
I have looked all the way through the service manual and tried many online...-
by retrorepairHello gurus, hope you can assist me...
I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
Thanks in advance.2 Photos -
by gurujiHello
I this Sony mbx-266 it powers
on all the voltages are normal the strange part iOS the caps key num key works which shows the machine has booted but no video at all internal dp and the ext vga or hdmi.I have changed the bios but same issue. What do I check ?? -
by YasaChSony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks ...
- Loading...
