LG 32LV3400 T-Con problem??
  • roamingraman
    • Oct 2012
    • 8
    • India
    A customer brought a LGLV3400 32" LED tv to my workshop for repairs...not a model sold in my region(India).. getting hazy picture with venetian blindness effect. Is it a T-Con problem?? following is the t-con board on it
    will it be possible to get circuit diagram of this?
    http://www.buyqual.com/media/catalog...-2467a-top.jpg
  • notallbad
    • Oct 2012
    • 1190
    Re: LG 32LV3400 T-Con problem??
    could we have a picture of the fault that shows on the tv screen, i.e. the hazy picture with venetian blindness effect
    • Clucas
      • 26
      I suspect it needs a seeing eye dog chip.
      • roamingraman
        • Oct 2012
        • 8
        • India
        striped lines found over the picture and also very hazy picture.
        what is 'seeing eye dog chip??'
        http://tinypic.com/r/3x3es/6
        http://tinypic.com/r/2zoaqer/6
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          What does it look like with a source connected?
          Have you tried a factory reset.
          Removed cleanded and replaced the cables to/from the Tcon?
          Looks like a voltage regulator in there - tested?
            May be LCD panel problem -- tab bonds?
            • roamingraman
              • Oct 2012
              • 8
              • India
              Thanks tom... Thanks selldoor. Let me try and find out!
              • kca
                by kca
                Hello all ~
                08-31-2025, 06:38 AM
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • THXFX
                samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
                by THXFX
                Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
                I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
                When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
                What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
                I check capacitors and diodes and didn't find any short IN MAINBOARD.
                Measured all power supply...
                03-20-2024, 03:21 AM
              • x_orange90_x
                TCL 50S535 bad tcon or panel issue?
                by x_orange90_x
                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                03-29-2025, 11:02 PM
              • advant
                by advant
                02-03-2020, 12:25 AM
