Philips 42PFL9632D/79 2-secs-to-black
  • pedro
    • 199
    • AUSTRALIA
    #41
    Re: Philips 42PFL9632D/79 2-secs-to-black
    The Samwhas on the two inverter boards have been replaced with Panasonic FR's. Recall that on the ESR meter the Samwhas measured 0.02 out of circuit (the same spec as the FR's) and I wasn't expecting the FR's to make any difference. No surprise - they didn't. But at least that variable has been removed from the equation.
    Decide that while I'm in here I may as well also fit the Philips/LG mod #2 kit, which has the Philips part# 996500095005. Philips are still trying to look it up ....
    Friends don't let friends buy Samsung ....
    • pedro
      • 199
      • AUSTRALIA
      #42
      Still no response from Philips service on their "repair kit" for these inverters.
      Have spent a lot of time (probably too much) searching for a schematic for these boards, using search terms LC420WU5, PNEL-T707A etc but no joy to date. Has anyone ever seen one?
      Without a schematic, and with the heat-testing not being able to identify *which* component is responding, this set looks destined for the dumpster shortly. I'm not thrilled by the prospect of a $50 chinese clone board as a long-term solution.?
        You don't need a repair kit; I thought it was two 4.7 ohm resistors and two TVS devices? Plus maybe a replacement of the IC?
        • pedro
          • 199
          • AUSTRALIA
          #44
          Actually I should have said "mod kit #2" but we are on the same wavelength. (The repair kit is the four FETs and the driver IC). No I don't *need* the mod kit but was intending on fitting it while the set was here *IF* the cold start issue was resolved.
          Interestingly, selecting a TVS diode for this application isn't as straightforward as some might expect. The ratio of clamping voltage to standoff voltage creates an issue, as anything with a >24V standoff will NOT have a clamping voltage less than the driver's specified 36V absolute max and so won't provide the presumed protection against transients.
          (I'm more familiar with the 1.5KE series transorbs, where 18V standoff devices 1.5KE22A are sometimes fitted to 12V mobile radio equipment. Their role is to go hard short and take out the line fuse if the equipment is inadvertently connected to a 24V vehicle. I was given one Motorola set as "beyond economic repair" that just had a shorted transorb!)
          On one German forum they were referring to a 100V device!
          The other idea - a zener - was part of mod kit#1 which wasn't a success, as the zener wasn't intended to handle the sort of transients that a true TVS does.
          Back on the heating subject, I've never liked the idea of using a soldering iron for this, and especially so on an epoxy case of a semi. But unless I can come up with a scheme to localise the heating to SMD-sized areas I don't see a way to progress this.
          Thanks for hanging around on this thread.
          • Recyclojunk64
            • 6
            Hi
            I am having a simmilar problem with a LC420WU5 inverter board as the OP. I don't have the back cover of the TV with me at the moment so can't give the exact model number, but I believe it's the same / simmilar to the one in the thread title.
            When the TV is turned on, the blue LED turns on on the inverter board which then emits a buzzing sound from the transformers. About two seconds later the LED fades off and the backlight cuts out. Then the backlight starts turning on and off about once every second, with the transformers still buzzing reasonably loudly when it's on.
            Firstly I checked the voltage outputted from the powersupply board and it's a clean 24volts going out to the inverters. I did check the caps on both the inverter and powersupply boards for ESR and they appear fine. I've also checked all the diodes on the inverter board and none were shorted out. Also the mosfets are fine aswell.
            I've looked at the voltages on the test pads for the master-slave interconnect cable, and found that the voltage on the SoftStart test pad (connected to pin26 on the main IC) is at about 3 volts while the backlight is on, and drops down to zero while it's off. I am not sure if this is just a symptom of the IC resetting for some reason or part of what's causing it to not work.
            I thought I'd have a peek at the flourescent lamps in it (easier said than done) and saw that they were external electrode lamps, and looked in good condition so I'm quite sure that isn't the problem.
            So does anyone have any idea of what might possibly be wrong with them? I I'd prefer fixing it myself than ordering a new set of cheap chinese clones. Is it likely to be one of the control ICs or transformers?
            Thanks for any help
            • Recyclojunk64
              • 6
              In the last post I meant SoftStart was pin 23 instead of pin 26. I must have miscounted them.
              Anyway I think I've found the problem.
              The BD9897FS controller IC on the slave was getting very hot (whereas the master one was cool). Between Vcc (26) and SW1 there was 10 ohms, whereas on the master the two pins had no connection between. (I desoldered the IC and there was still 10 ohms between them). SW1 is the "lower rail voltage for HN1 output". As far as I can tell it is a reference input for the high-side n-mosfet gate-output, and is connected to the source of the mosfet that HN1 drives. So it is of course also connected to the discharge of one of the low-side mosfets, meaning that alot of current will flow out of it as that mosfet is conducting, heating up the main IC. But more importantly the high-side mosfet driver won't be driving the gate at the correct level.
              I've ordered a replacement chip (plus a few spares) under the assumption that nothing else on the board is damaged. Will post back when they arrive as to whether it works again.
              • pedro
                • 199
                • AUSTRALIA
                #47
                You're in Perth too? Want this set to play around with? Please. It's gathering dust right now and I need the space it is taking up.
                • alro7779
                  Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                  by alro7779
                  Hello, guys!
                  The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                  09-14-2025, 12:25 AM
                • G33RT
                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                  by G33RT
                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                  It does power up when pressing the power button.
                  I already try the power button while plugin the plug with no result.
                  Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                  Could this be an PSU or eMMC issue ?
                  07-19-2025, 03:43 AM
                • double_DD
                  Philips curling iron - is this a common AC cable?
                  by double_DD
                  Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                  As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                  Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                  08-18-2025, 10:04 AM
                • janos6662000
                  Philips 47PFS7509/12 LCD TV problem
                  by janos6662000
                  Hi
                  I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                  When i applied cable signal to check image, i had normal picture, but TV was restarting.
                  I downloaded original firmware and applied the update, but the problem remained.
                  From a colleague i received a "factory package software" which is a lot bigger.
                  I made another firmware update, but still did not solve the problem.
                  Somewhere on the way the error got worse, because at the moment the...
                  08-12-2025, 12:54 PM
                • aidanmo
                  Philips 43PUS7506/12 - Loud blown out sound
                  by aidanmo
                  I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                  I thought maybe the speakers got damaged, so I replaced them - no dice.
                  • Using the internal speakers, it always happens.
                  • Using the headphone jack, it never happens.
                  • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                  02-28-2025, 03:13 PM
