Sony KDL46HX800 Sometimes wont power on 3 blinks
  • jamesb6
    • Nov 2012
    • 20
    Re: Sony KDL46HX800 Sometimes wont power on 3 blinks
    I would love to get the service manual, but I cannot locate it.
    Does the tv do some sort of test when you plug it in to determine if 12v is being produced by the power supply. Like a brief power up to test the set....or do you think the main board has lost its mind and just thinks there is a problem
    • jamesb6
      • Nov 2012
      • 20
      I am unable to locate the service manual. Do you have a source
        Did you see my post 17?
        • jamesb6
          • Nov 2012
          • 20
          Yeah. But when I look for KDL40EX620 it shows no results. My tv has a problem like the kdl46hx800 in this thread
            EX600 may be close to what you have:
            • jumpinjohn
              • Mar 2013
              • 28
              (I may be jumping the gun here)
              Thank You for the post of the service manual Budm.
              Well from what I am reading in the manual page 26, it appears to be the BAL board. (As Mt.Man suggested above)
              (I doubt it's the other option "speaker", since I always use external speakers)
              It references F3700, IC3700, etc
              WHAT DOES this mean?
              Does the whole board get replaced, or is this a reference to a component that can be replaced?
              BAL Board is Part number A-1778-484A (for mine, the 46HX800)?
              Googling the part number all I can come up with is $403
              https://www.servicesplus.sel.sony.co...A1778484A.aspx
              Lastly, where can I purchase one of the boards at the lowest price?
              • jamesb6
                • Nov 2012
                • 20
                Hey John. Check Ebay, but make sure the sell has a very good rating and be sure there is a solid return policy. Also, www.shopjimmy.com is a great parts source.
                • jumpinjohn
                  • Mar 2013
                  • 28
                  I checked both but they are out of stock.
                  Shop Jimmy has it listed at $131
                  http://www.shopjimmy.com/sony-a-1778...-bal-board.htm
                  $199 +$117 core at http://www.tvserviceparts.com/A-1778-906-A.html
                  I'm not really sure of the part number in the manual it says A-1778-484A Everywhere else seems to say 906A
                  Anyone else know of a cheaper source?
                  (I'm not in a huge hurry, I could wait for a china delivery.)
                  • jamesb6
                    • Nov 2012
                    • 20
                    The 484A is probably a board number. The part number will be on a barcode label that should be just below the RCA inputs. The first letters/numbers are the part number.
                    Zoom in on this photo and the part number in pink (in the photo) that is where you will find it on your board
                    http://assets.shopjimmy.com/media/ca...-906-a-top.jpg
                    I will see if I can find another source for you
                    • jamesb6
                      • Nov 2012
                      • 20
                      These guys might have one. I didn't see an "out of stock" on the page
                      http://www.moduslinkptstvboards.com/...6A-P30382.aspx
                      • Mt.Man
                        • Jun 2012
                        • 53
                        A-1778-906-A is from the Sony service manual for your model. The boards from Sony does not come with software installed. Make sure you have the latest software on hand when you install the replacement board. Also the USB stick must be formatted in FAT32.
                        • jamesb6
                          • Nov 2012
                          • 20
                          Well, concerning my KDL-40EX620, I have replace my main board and no more 3 Blinks when I plug it into the wall. I still don't have a working set. Now when I turn the set on via the power button or remote, it begins to power up shows Sony, (backlights on) and then goes back to protect and flashes the red standby led 10 times. I did a little research and there is some indication that it could be the led driver board or T-Con board....but it is not. I have now replaced both and the set is behaving the same. I also upgraded the Main Board to the latest version by pressing and holding the up arrow button on the remote and powering the tv on via the power button on the side of the television. The software did update (my usb drive flashes a status as it is being accessed). The behavior is also the same after updating the tv (flashes Sony and shuts down, status led 10 flashes). There is only one board left. The power supply. I would sure like to hear if anyone else has seen this and can verify the power board is the issue, as it is the most expensive of the boards.
                            The original main board would work fine occasionally though?
                            • jumpinjohn
                              • Mar 2013
                              • 28
                              Darn James, that stinks. I was hoping to hear better news. I found a main for my set for $115, but haven't gotten it yet.
                              Tom, that was mine that is working occasionally. Not sure about James'
                              • jamesb6
                                • Nov 2012
                                • 20
                                With the original main board the tv starts flashing the status led as soon as it is plugged in
                                  It may be that main board is not an exact compatible replacement. Sony LCDs are very fussy about that.
                                  • jamesb6
                                    • Nov 2012
                                    • 20
                                    Well, I think the problem is that I replace the main with a part from a 3D version of the same TV. The TV I have is a KDL-40EX620 and the main board (same part number, supposedly compatible) came from a KDL-40EX720. The 10 blink is indicating an emitter error...duh...no 3D emitter is in my 620.
                                    So, my next question before I order a board from a 620 is....can I trick the main board into thinking that the emitter is present? If I can do that, I may be able to change the model number in the firmware....
                                    • jumpinjohn
                                      • Mar 2013
                                      • 28
                                      Hey James any luck with yours?
                                      I've been leaving mine on. Shut it down by mistake a few times, and it started right back up. I guess it's possible that it was/is a hot/cold issue.
                                      In the meantime, the TV in the bedroom (MEMOREX MLT3221) blew out a cap while it was on last week. Stunk up the room and the picture would come on, and fade out in about 5 secs. Found one bad cap, but replaced two, and it's fixed.
                                      • jamesb6
                                        • Nov 2012
                                        • 20
                                        Yeah. I got mine fixed. I just ordered in another main board that came out of the exact model. It fired right up and works great.
                                        • jumpinjohn
                                          • Mar 2013
                                          • 28
                                          Great good to hear. I'll post back when I get around to ordering one.
                                          • jason123
                                            Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
                                            by jason123
                                            Hi there,
                                            I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
                                            So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
                                            I see 2 posts that are relevant:
                                            https://www.badcaps.net/forum/troubl...j-oled-5-blink
                                            https://www.badcaps.net/forum/troubl...g-hardware-dev...
                                            10-29-2025, 02:01 PM
                                          • matwan
                                            Sony XR-55X90J 5 blinks
                                            by matwan
                                            I have problem with SONY 55X90J. After several check status is as below;
                                            1. Running power board as stand alone:
                                            TCON_12V =~ 12.6V
                                            EVDD V On Max 24V= 19V.
                                            2.
                                            Running power board with TCON as stand alone:
                                            Effect as below, attched.
                                            3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                                            "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                                            Best regards....
                                            09-28-2025, 04:26 AM
                                          • GoodCapDude
                                            Sony XBR-75X940E intermittent 6 blinks error code
                                            by GoodCapDude
                                            Hi everyone. First post on Badcaps!
                                            I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                            09-20-2025, 06:07 AM
                                          • AK_777
                                            Sony KD-65A1 Repair – 4 Red Blinks Error
                                            by AK_777
                                            Hi everyone!
                                            I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                            Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                            02-20-2025, 04:15 PM
                                          • jchon
                                            Sony A1e 5-blinks help
                                            by jchon
                                            Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                            I found the service manual, which was critical to know where to probe.
                                            https://www.manualslib.com/manual/20...1e-Series.html
                                            With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                            Unfortunately the 5-blinks...
                                            06-28-2023, 11:52 AM
