Hello Everyone,
I have spent some time today trying to get a Beko 30inch LCD tv working.
I do not have a specific model number, as it has it's case removed.
On the Firmware Chip was - LT30FLF ver 2.9 2005
Screen goes blank after 2 seconds, sound is good.
The Inverter board is a Model V144-001.
Main Board is Model V2327B/D 111-A48F.
The LCD panel is V296W1-L11.
I went through the Great post on troubleshooting, this is what I found,
1- Bad capacitors,
I replaced them all on the Inverter board, all originals checked good when I removed them, I checked the power supply, it is an outboard power supply, not inside the tv, all checked as good using my capacitance meter.
2- Shorted transistors,
not sure where to check yet, help please if you can.
3- open Fuses,
checked every fuse I could find, all are good.
4- Bad transformers,
checked with multimeter, 940 to 960ohms.
5- Bad CCFL,
unplugged 2 at a time, turned tv ON, still same black screen after 2 seconds.
6- Bad Diodes,
Will test further, but would appreciate help here also.
7- Bad/Cold/poor solder joints,
Checked every board with magna fine glass, all solder joints were good, plus unplugged and replugged all socketed cables.
8- I measured the various voltages, found all normal from what I can tell.
Now off to find some schematics
Much Appreciate any comment or Suggestions.
Cheers
Steve
1- Bad capacitors,
3- open Fuses,
5- Bad CCFL,
6- Bad Diodes,
Cheers
Steve
