Baird JO37BAIRD(A) No Power
    Re: Baird JO37BAIRD(A) No Power
    these are the parts that are in the repair kit for mlt666 boards maybe check these parts out on yours to see if there ok?
    http://www.ohmsupplies.co.uk/REPAIR-...66-VERSION-A-B
      thinking of just buying a new power board as those components look small n tricky :/ can get a board on ebay for £30 if thats worth it
        its one of them £30.00 is not bad just make sure you can return it if faulty also has your board got a sticker on of the full model number as some of them have a rev 1/2/3 etc number after it which could mean it may not work in your set.
        i would for now continue to fault find although all those items are in that kit it may be only 1 or 2 bits have gone faulty and could save you some cash. how i some times find faults as i am still a newbie at this is to look whats in the repair kits then test them on my faulty board i would say you have a good chance of finding the faulty part then.
          ahh ok thats a clever way of thinking.. thanks for help
            is this the same as yours
            http://www.ebay.co.uk/itm/MLT666-REV...ectorid=229508
            yes the shop is new to ebay no feedback but we all had to start somewhere also returns accepted and there address is listed i would from them imo if its the right board a very good price imo
              no mate im afraid mines is REV1.0. dont think the REV2.8 Would work, had a look on ebay and the cheapest REV1.0 is £30
                might be worth asking if this is a rev1.0 also a good price
                http://www.ebay.co.uk/itm/Megmeet-ML...item35c5490334
                  ive asked mate but that looks likes llike a REV2.0 or above... some of the components on that one look a little different and bigger
                    pity both was good prices back to fault finding.
                      Vinceroger69 i mailed the guy about one of the listings you sent and here is the response i got > you think it would do the trick
                        i would take a chance myself.
                          i did mate i purchased last night so will update to let other people with the same problems know if they can purchase these boards rather than the original
                            when it comes just make sure the plugs which say the voltages on all match up ok ie 24 volts grounds etc it should be ok will be a cheap fix it fixes it.
                              board came today and there a little different Vinceroger69. for some reason there was no where to put the power for the mainboard on it
                                pictures of both board connections might help even the seller said it was the later version so its the alternative to the one you have so confused now to so what are the differences you can see?
                                he should accept it as a return as he was even sure it would be ok and work and he a does accept returns.
                                  theres a 4 pin connecter missing on the board the seller sent me, the 4 pin connection thats missing on the same as mine is to power the Mainboard. i have uploaded mine and the seller one to show difference and circled the 4 pin thats missing
                                    u guys think i could put the Revision 1.1 in this tv as its 1.0 in it just now but just came across this on ebay ?? help appreciated thanks
                                      Well, in the worst case, you could probably cut the wires off the current connector and solder to those points. You may need a small drill to get through the plated solder, if you can't wick it out.
                                        Tom66 do you mean on the board i already ordered on ebay or the one i am thinking of ordering ?
                                          The one you have that has the missing connector?
