Panasonic TH-37PX8B
  • anotherdude
    • Feb 2013
    • 488
    Panasonic TH-37PX8B
    Friends just got this problem with this tv
    basically it's a black bar going through the screen with what looks like static
    not had a chance to get it open yet just thought i'd see any suggestions before i look for the obvious
    Re: Panasonic TH-37PX8B
    Looks a lot like an eBay auction I saw a week or so back; hope they didn't buy it for repair, because the plasma panel is bad and this fault is not repairable.
    • vinceroger69
      • Mar 2012
      • 6714
      tom are most/all vertical black bars panel failures as seen a couple on gumtree with this problem in the center of the screen.
        Almost always a panel failure. Regional defects are a thing to avoid for both LCD and plasma displays.
        • anotherdude
          • Feb 2013
          • 488
          he was the one the selling it, got messed around by a buyer and decided to try get it repaired
          thought it was worth a ask anyway
          the parts inside worth anything as i think it's a fairly old model?
            Not that old (2008~2009 I think), yeah, they're worth a bit. Probably £30~50 total.
            • anotherdude
              • Feb 2013
              • 488
              thanks, suppose he can try and part it out or try again on ebay
              least i know now for the future that defects like this aren't repairable
              • BigPete
                Panasonic Heatpump Dryer Repair
                by BigPete
                I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                Unfortunately the whole machine has to come apart to fix it.
                I have...
                11-01-2025, 06:40 PM
              • Andre Gilbert
                by Andre Gilbert
                Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                11-20-2024, 08:52 PM
              • AquaMan Ua
                by AquaMan Ua
                05-17-2025, 09:40 AM
              • stecos
                Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                by stecos
                Hi everyone!
                For my passion for technology I'm now collecting several...
                11-28-2022, 11:39 AM
              • aa10aa10
                Panasonic Toughbook CF-33 mk1 BIOS repair
                by aa10aa10
                Good day,
                I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                01-21-2025, 06:13 AM
