Samsung 46" lcd ln46b650 vertical lines and a gridlike pattern on right half
  • snake91876
    • Feb 2013
    • 236
    Re: Samsung 46" lcd ln46b650 vertical lines and a gridlike pattern on right half
    Tried a new main board and it does the same thing. I guess we can surely say the lcd screen is toast the only other thing it could be is the lvds cable , anybody had trouble!
    • tibimakai
      • Jan 2012
      • 3680
      If the chips in the ribbon cables are way to hot then most likely they are toast.
      Did you checked them for burned marks, before you ordered the mainboard?
      You can try resetting the mainboard, see if there are any updated firmware. Check in the service menu, if the right TV is selected.
      That's all you can do
      • snake91876
        • Feb 2013
        • 236
        Some of the chips in the ribbon cables burn your fingers they are so hot when you touch them. I checked to make sure right tv is selected , i guess she is toast man i got this one for $30 and was hoping to fix it for the living room. Well i guess ill sell the parts and move on to the next one.
          They do run hot, that is why they use the frame as the heatsink, the thermal pad helps making good contact between the chips and the frame.
          Never run the panel too long without the frame in place. They get up to more than 150F.
          https://www.badcaps.net/forum/showthread.php?t=25371
          • snake91876
            • Feb 2013
            • 236
            Anybody got any final ideas before i start selling parts?
            • tibimakai
              • Jan 2012
              • 3680
              The frame touches the driver ICs?
              I would try using that material that bud has used on those chips and see if it helps. Maybe if they get cooler, they may still work.
              • snake91876
                • Feb 2013
                • 236
                Well i checked ics with a laser and all were about 85 to 90degrees f.
                I guess im done , bad lcd display panel. Parts are for sale! Thanks for the help im gonna go buy me something else to fool with.
                • Tealtuna
                  • Jul 2013
                  • 7
                  I want to bring this one back from the dead and maybe get a little feedback..
                  Here are a few images of my problem on the same model of TV (LN46B650xxx).
                  I found a T-Con board for $20 that is new and figured this is a likely problem. Squeezing the panel (with bezel on) didn't seem to do anything.
                  However.... now the TV is like the last picture (of this post) where the left side has horizontal thin black lines that fade away on the right side of the screen... about 1/8" apart.
                  If this is a bad idea feel free to say something ;-)
                    So the main problem is fixed? You likely still have a defective T-con but one which is only slightly defective. I fixed the european 40" version of this (LE40B652.) Original T-con was completely bad. First replacement T-con had problems (green shadowing on image) and second t-con fixed it properly, most sellers do not seem to test the T-cons properly. Bottom line is if you see a significant change in the symptom you're probably on to the right part. See if you can send the T-con back.
                    • Tealtuna
                      • Jul 2013
                      • 7
                      Actually since I posted this... I went to replace the T-Con but found that the one I was sent was not the correct one for my TV! The one within the panel was much smaller...
                      I am returning the one I have and seeing if they can find me a proper one... I will post my results.
                      But to clarify, the last image is how the screen looks when I posed this... The problem seems to have went away partially. But I also agree if I see any change at all I'll pursue it.
                      • Tealtuna
                        • Jul 2013
                        • 7
                        Finally an update.
                        I replaced the t-con board with a proper one for my model... installed and turned on..
                        and it is creating the exact same problem with no change :-(
                        Really bummed at the short life of this LCD which is only 4 years old and did not see heavy use... Any other suggestions would be greatly appreciated. Also ideas of what to do with the old TV if I should sell the boards from it on this site, ebay, etc? Sell the whole unit?
                        • Tealtuna
                          • Jul 2013
                          • 7
                          Shameless bump for my last post questions^
                          Damn I really wanted this thing to work!
                          • Tealtuna
                            • Jul 2013
                            • 7
                            sweet
                            • lnlkustomz2007
                              • Aug 2013
                              • 11
                              • usa
                              #54
                              hi, I am a newbie, pretty good electronics backgournd and want to get into doing tv repairs. I already bought a few broken ones to teach my self on. This tv is one of them and im getting the same problem. turn it on and i have vertical lines in the center.. as tv gets warmer i get more lines. sometimes the lines will change positions. they aren't always in the same place. i do hear a loud buzzing noise coming from the power board. is that normal? also ive seen people talk about pressure on the TAB, what am i looking for there. THank you for any help.
                              • Stanley1843
                                by Stanley1843
                                06-29-2024, 11:54 AM
                              • ItalianSat
                                LCD SAMSUNG LE40A656A1CXXE - Vertical Lines on Half of The Screen?
                                by ItalianSat
                                Hello Everybody,
                                I have a 40 inch LCD SAMSUNG LE40A656A1CXXE. Its problem is that there are Vertical Lines on Right Half of The Screen.
                                Interestingly enough, when I move my mouse (in the case if connected to a PC) or when I am watching the TV, lines also move. At first appearance, I had thought that the problem might arose from loose vertical ribbons (COF), but when I opened up the TV for further investigations, I realized that the problem cannot be solved by touching them.
                                Moreover, I detached the T-CON board for a new round of investigation. I personally...
                                06-28-2022, 06:02 AM
                              • visionbluedemon
                                Help. Sony kd-65x85dj vertical lines
                                by visionbluedemon
                                First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                tried blocking LC lines too, but same results
                                is it lcd panel issue or tcon board issue?...
                                Yesterday, 04:56 AM
                              • gpo23
                                Sony KDL-40V3000 - Vertical lines
                                by gpo23
                                i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                With the new t-con the color are good but there are vertical lines on all the screen :
                                I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                Is there a way to fix the vertical lines on the new t-con ?
                                Thank you for your help
                                gpo23...
                                10-04-2023, 09:11 AM
                              • Firentiosi
                                1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                                by Firentiosi
                                Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                                The issues are as follows: the...
                                11-27-2024, 12:33 AM
