Samsung 46" lcd ln46b650 vertical lines and a gridlike pattern on right half
  • snake91876
    • Feb 2013
    • 236
    Re: Samsung 46" lcd ln46b650 vertical lines and a gridlike pattern on right half
    Where on the tcon board would the voltage be checked i have never checked that on one but im sure i can. Is it near the lvds cable input or general location to look. What should the voltages be and do i just ground to metal chassis or frame while checking i know some test points need to be grounded in certain spots.
      It varies with each T-con. You will see white lettering next to a gold test pad.
      • hienton2
        • Sep 2009
        • 183
        I still think of main board. But you said Tcon at bottom of panel. Then watch for windex issue That make board corrosived
        • snake91876
          • Feb 2013
          • 236
          Ok here are the TCon readings
          VON 23.4v
          vOFF -13.7v
          • MisterD
            • Oct 2012
            • 668
            Spray freeze spray directly on the tab bonds one at a time waiting 10 seconds on each before proceeding with the next, try pressing on them after using the freeze spray.
            You can also try heating the tab bonds with a hair dryer and pressing on them while they are warm, sometimes they have to be heated or cooled before you will get any results.
              Both VON and VOFF look fine to me. There is also usually AVDD (15~20V), but this is generated on the same supply as VON/VOFF so all three or none should be present.
              • snake91876
                • Feb 2013
                • 236
                Well i dont know what direction to go now. You think its the lcd panel or could i have main board trouble.
                  I'm thinking panel or t-con. Doubt it's the main.
                  • snake91876
                    • Feb 2013
                    • 236
                    My instinct tells me t-con , i just fixed an insignia 47 lcd with a tcon. It would play for 5 mins do some weird picture colors and go out but still have sound. I feel like this is doing the same thing as the picture just gets worse and worse if you play 30 minutes or so it almost gets a ghostly white all over the screen but images can still be seen. Then i read about the samsung panel failures and have been scared its that and debating paying much for a t-con. Do you think if it was panel it would be progressive failure like this or would it be failing right at turn on.
                    • snake91876
                      • Feb 2013
                      • 236
                      Heres a picture of the same ln46b650 a guy is selling the tcon from on ebay. He claims the lcd panel is bad. This is what mine looks like just thought it might be a better picture where you can see it. Maybe i do have a bad panel or maybe he dont know what parts are good or not.
                      • snake91876
                        • Feb 2013
                        • 236
                        So i followed mister D's instructions above and went back and re-analyzed the tab bonds on my lcd screen edge. I sprayed with cold spray and heated with a hair dryer at each of the 16 spots. I pressed them and saw no changes what so ever in picture. But as usual as the picture warmed up it got worse. I flexed the screen and moved it a little at the tab bonds and get no kind of change in my picture. Anybody?
                        • snake91876
                          • Feb 2013
                          • 236
                          Well I got the new T-con in the mail and popped it in and bam same darn lousy picture. I guess its not that cause it did the same exact thing in progression. Well the big question now is do i try a main board or call it a bad lcd display and sell my parts. Thanks matt
                          • snake91876
                            • Feb 2013
                            • 236
                            Anybody , what do you think?
                            • tibimakai
                              • Jan 2012
                              • 3680
                              There are some chips in the 16 ribbons, do they heat up a lot?
                              Do you have sound?
                              • DakotaKid
                                • Nov 2010
                                • 165
                                #35
                                I had a similar problem with this same model and it was the mainboard. I popped in a replacement from a TV with a broken screen and it fixed the problem immediately. I also have one with tab bonding problem where the picture starts out half dark and with lines and in about 10 minutes it pops in clear and perfect, especially if i give it a slight twist.
                                • snake91876
                                  • Feb 2013
                                  • 236
                                  I have good sound the chips in the 16 ribbon cables get hot. Dakota kid you have given me hope. i may try a mainboard. Are the chips supposed to heat up. i have twisted and flexed
                                  and cant find a bad tab connection.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    Ifthey way to hot, them maybe the driver ICs are damaged. Inspect them for burned marks.
                                      The ICs on these sets run much too hot which is why they fail so often...
                                      • snake91876
                                        • Feb 2013
                                        • 236
                                        Anybody else think i should go for main board!
                                        • fxdfireman
                                          • Nov 2010
                                          • 86
                                          Did you try a main board? Did it fix it?
                                          • Stanley1843
                                            by Stanley1843
                                            06-29-2024, 11:54 AM
                                          • ItalianSat
                                            LCD SAMSUNG LE40A656A1CXXE - Vertical Lines on Half of The Screen?
                                            by ItalianSat
                                            Hello Everybody,
                                            I have a 40 inch LCD SAMSUNG LE40A656A1CXXE. Its problem is that there are Vertical Lines on Right Half of The Screen.
                                            Interestingly enough, when I move my mouse (in the case if connected to a PC) or when I am watching the TV, lines also move. At first appearance, I had thought that the problem might arose from loose vertical ribbons (COF), but when I opened up the TV for further investigations, I realized that the problem cannot be solved by touching them.
                                            Moreover, I detached the T-CON board for a new round of investigation. I personally...
                                            06-28-2022, 06:02 AM
                                          • Falki
                                            Colorful LCD Vertical Lines on Samsung ue55es8090
                                            by Falki
                                            Hello there, ive recently found an older 55inch Samsung SmartTV.
                                            A similar issue has been posted as well but also with no actual response ...
                                            08-12-2025, 04:19 AM
                                          • visionbluedemon
                                            Help. Sony kd-65x85dj vertical lines
                                            by visionbluedemon
                                            First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                            Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                            tried blocking LC lines too, but same results
                                            is it lcd panel issue or tcon board issue?...
                                            07-25-2025, 04:56 AM
                                          • gpo23
                                            Sony KDL-40V3000 - Vertical lines
                                            by gpo23
                                            i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                            With the new t-con the color are good but there are vertical lines on all the screen :
                                            I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                            Is there a way to fix the vertical lines on the new t-con ?
                                            Thank you for your help
                                            gpo23...
                                            10-04-2023, 09:11 AM
