Element TV Proview board problem
  • grtrunner02
    • Feb 2013
    • usa
    I'm new to the site and new to electronics repair in general. I picked up an element tv that would power on but the screen wouldn't turn on. I replaced the two 10uf450V caps on the proview board. The screen now turns on and I can play with the menu. My question is as soon as I plug the tv in I get a whistling sound. Also when you touch the top (opposite of the lead side) you get an electrical shock. Is that normal? Any Idea what the whine noise is? Any help would be great.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Element TV Proview board problem
    Touch the top of what?? - Quite dangerous touching anything inside a TV of you dont know what you are doing!!
    Whining whistling screeching could be capacitors -or lamps- try and establish where the sound comes from and turn down the brightness - see if that helps.
    • cashkennedy
      • Aug 2011
      • 668
      Why did you replace the 2 450v caps? Were they blown / domed? Did you replace with caps for 450v or higher? Are any of the other capacitors on the power board leaking, or bulging, or domed?
      Often a whistle noise comes out of capacitors that have blown / and are leaking. As selldoor said, try adjusting the brightness and see if the noise changes and try to tell where its comming from.
      Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
      • grtrunner02
        • Feb 2013
        • usa
        @selldoor...I knew what i was touching. I'm not an expert in electronics but i knew there should not be electricity on the top of the cap (part that domes when bad). I guess i should have phrased it differently.
        @cash I replaced the 2 caps (with the same size but panasonic brand) because they had a slightly domed. I do not see any others leaking. T?he tv works now just a faint whistle noise.
        I re-soldered the new caps in and the electricity is no longer felt on top of the 2 replaced caps. still have a very faint whistle.
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • huj3r
          Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
          by huj3r
          Hi there!
          I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
          Photo of the situation after the black shadow dissipates:
          After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
          I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
          > This indicates HFR Communication error. [ HFR Communication...
          08-15-2023, 10:55 AM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
