PHILIPS 50PFP5532D-05 Image Issue
  • Andyd1970
    • Feb 2013
    • 374
    • united kingdom
    Hey Guys,
    Another one to tax the brains! Just started one day to give a picture as per the attached image, sorry it was taken on my phone as the TV is at my friends house and is soo heavy we decided to leave it alone till we know if we can fix it.
    The sound is fine, all connections externally have been checked.
    Andyd
    Re: PHILIPS 50PFP5532D-05 Image Issue
    Bad digital board. Does it affect all menus and all inputs?
    • Andyd1970
      • Feb 2013
      • 374
      • united kingdom
      Hi Tom,
      You are a super star helping me, thank you.
      I ahve checked with my friend and he gets the same image from any external device and also when he uses the TV menu's he gets the same image.
      Andy
        So, the lines cover the menus on the display?
        • Andyd1970
          • Feb 2013
          • 374
          • united kingdom
          I have spoken to my friend and yes you get the same image when you select the TV menu and also if you plug it into an analogue aerial.
          Andy
          • Andyd1970
            • Feb 2013
            • 374
            • united kingdom
            Hi Tom66 and all you other great guys,
            Any thoughts on this Plasma? what ever you select you get this banding over the whole screen. Just wondered if any of you have seen this before and if so can you suggest a part to order? Its just my friend is getting ear ache from his girlfriend as the TV is on the floor as it is sooo heavy and difficult to put back up, he doesnt want to put it back up till hopefully it can be fixed
            Andy
              It is a control board issue. Only way to be sure of the part is to open it up.
              • Andyd1970
                • Feb 2013
                • 374
                • united kingdom
                OK great, when I open it up what should I be looking for? voltages etc?
                Andy.
                  Your camera, to take pictures of the chassis. Everything is working apart from those lines, so it's not going to be a PSU issue.
                  • Andyd1970
                    • Feb 2013
                    • 374
                    • united kingdom
                    Hi Everyone,
                    As requested pictures of the chassis..
                    Any suggestions?
                    Thank you Andy
                    PS - Its realllly cold in East Kent today
                      Here's the control board.
                      Can you remove the main board frame, and get a closer shot of it?
                      PS - It's extremely cold in Leeds.
                      • Andyd1970
                        • Feb 2013
                        • 374
                        • united kingdom
                        Hi Tom,, See pics of the PCB.
                        Andy
                          See pic.
                          Power OFF and unplugged.
                          Place HDD setting jumper across pins 3-4 of the 4 pin block CN2007. A piece of bent wire works too.
                          Disconnect LVDS, the glued connector, at the main board end (not on the control board... the glue will make it a nightmare.)
                          Power ON normally.
                          Test patterns should appear. Do the lines cover the test patterns?
                          If YES: Control board 100%.
                          If NO: Main board 95% or Control Board.
                          • Andyd1970
                            • Feb 2013
                            • 374
                            • united kingdom
                            Hi Tom66,
                            Just did as you suggested and the banding was still there. So guess that proves control PCB, just go to find one now.
                            Andy
                              Can we see a picture of the test patterns?
                              • Andyd1970
                                • Feb 2013
                                • 374
                                • united kingdom
                                Pics below
                                  If I were to guess a particular fault on the control board I would say a problem with the RAM or BGA bondings on the processor. I note it is around £50 from several suppliers.
                                  • Andyd1970
                                    • Feb 2013
                                    • 374
                                    • united kingdom
                                    Thank you Tom ,your a star.
                                    When you say bonding could it be a cold joint? is it worth reflowing anything?
                                    What suppliers have you found that have the PCB?
                                    Thank you again
                                    Andy
                                      I would give reflowing a go -- nothing to lose.
                                      eBay was £50, this guy has two:
                                      http://www.ebay.co.uk/itm/SAMSUNG-PH...item19d6a86c70
                                      • Andyd1970
                                        • Feb 2013
                                        • 374
                                        • united kingdom
                                        Hi Tom,
                                        The PCB arrived today, fitted it to the TV and hey presto it works!
                                        Thank you for your help, I will certainly remember what you have explained to me.
                                        Really appricate your help.
                                        Andy
                                        • remmurdmd
                                          Vizio E65-E1 strange image issue
                                          by remmurdmd
                                          Hi everyone. First new thread here. I picked up a TV on the side of the road. It appears to function correctly with the exception of an image issue I'm unable to describe. I've searched for “double picture” and “double image” all over the web and all I get is repair videos for when the picture is blurry and the connections are getting interference between the display panels and the t-con board. I believe this is a t-con board issue, but I haven't found anything telling me conclusively that this is where my issue is. I'd appreciate any assistance you can provide. I live a pretty busy life...
                                          10-02-2022, 09:12 PM
                                        • alro7779
                                          Philips 32PFL4901/F8 BA5DFGG0201 1 Backlight is present but no image
                                          by alro7779
                                          Hello there!
                                          Have this Philips with no image at all. When I plug it to the outlet, it turns on without pressing the power button, and after a moment, it turns off, then starts again. I checked the 12v and 3.3v voltages on the main board connector that goes to the T-con, but it only has the former (12v). Any clues, guys?...
                                          08-07-2025, 11:53 AM
                                        • tuner2000i
                                          Philips 65PUS8518/12 distorted image after main board replacement
                                          by tuner2000i
                                          hello everyone,
                                          I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                                          The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                                          07-15-2025, 01:15 PM
                                        • Ancient1
                                          Strange LG TV issue : Image vertical lines in black screen
                                          by Ancient1
                                          Hi
                                          Asking for a friend.
                                          I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
                                          but here its the opposite !
                                          TV has new T-con = same issue
                                          A missing panel voltage would have global effect
                                          So , what should one do ? how can I find where the fault is ?
                                          Thanks !...
                                          02-05-2025, 03:37 PM
                                        • ovrax
                                          Philips 55PUS6804/12 turn on & off (probably backlight issue)
                                          by ovrax
                                          First of all, please excuse me as I'm quite new to this field.
                                          I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
                                          I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
                                          The Ambilight works perfectly and stays on.
                                          No sounds.
                                          Thanks in advance.
                                          08-25-2024, 04:33 AM
