Vizio VX37L HDTV10A Works perfect except AVI video is distorted
  • gijoey198079
    • Dec 2012
    • 53
    Using cable or digital antenna the picture is perfect and normal, HDMI is normal as well, when you use the AVI inputs the picture is distorted, kinda blurry, and the color is a little off, way too much white and almost looks like a little static.
    I have already tried a few different cables and same result, tried it with the wii, dvd player and ps3 all the same outcome.
    Re: Vizio VX37L HDTV10A Works perfect except AVI video is distorted
    Vizios are well known for regulator issues. Such a problem could cause distortion on only the analog inputs.
    See this thread for a guide.
    https://www.badcaps.net/forum/showthread.php?t=22231
    • gijoey198079
      • Dec 2012
      • 53
      I got another one here with busted screen all the boards are good, think I should just change out the motherboard and test it? I don't have but $10 in the one with busted screen so it would be easier to do than trace down the issue.
        I would do that.
        Then eBay the remaining working boards as they are rare and you should get a good price.
        • gijoey198079
          • Dec 2012
          • 53
          Think a firmware update may do it?
          • martyparish
            • Dec 2012
            • 313
            Considering you have two boards, one good one. I would at least try to fix the original(you can use the good one for reference when measuring voltages). As Tom said, it could be a regulator and end up being a cheap fix. (Then you also have a main board to sell!)
            • gijoey198079
              • Dec 2012
              • 53
              Well I went and pulled the other board and there are a few differences, both are the same exact model but different part numbers on board. Should I change out the psu, main board and t-con just to be on the safe side?
                It'll likely work as long as the t-con is the same and all the connectors are the same.
                • gijoey198079
                  • Dec 2012
                  • 53
                  Testing some of the voltage regulators on the board, can't find exact data sheet for some so any help is great. Below is the regulators with what the reading is.
                  AZ7805T-E1 @ U3
                  1. 11.56v
                  2. 0v
                  3. 4.83v
                  AMC1117 @ U4
                  1. .83v
                  2. 3.21v
                  3. 4.93v
                  AMC1117 @ U8
                  1. .88v
                  2. 3.16v
                  3. 4.96v
                  AMC1117 @ U33
                  1. .81v (screen flickers for a second when i touch this pin with probe)
                  2. 3.18v
                  3. 4.93v
                  AMC1117 @ U7
                  1. .02v
                  2. 1.23v
                  3. 3.17v
                  K1117S15 @ U 9
                  1. 0v
                  2. 1.46v
                  3. 3.18v
                  AMC1117 @ U2
                  1. .91v
                  2. 2.24v
                  3. 4.95v
                  1084 @ U10
                  1. .67v
                  2. 2.53v
                  3. 4.93v
                  This is all of the 3 pin voltage regulators, I'm still not real clear on how to test the 4+ pin ones. By my calculating all of these are bad, 1 is close to range. Is that normal for it to be that bad but screen still look good on certain inputs?
                  • gijoey198079
                    • Dec 2012
                    • 53
                    First pic is on AVI using DVD player, 2nd pic is cable, big difference.
                      U4, U8, U33 look bad.
                      The output at pin 2 should be equal to reading on pin 1 + 1.25 = pin2 output.
                      I.E. PIN 1 is 0.25v, then pin 2 should be 0.25 + 1.25 = 1.5v.
                      u2 is a tad above 2% spec.
                      Please see link at the bottom of my signature to learn more.
                      Please also check your meter's batteries to make sure it is good.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Hmm, I can't recall 3 voltage regulators all going bad on one board.
                        The battery in the multimeter seem to work because U9 reads 1.46 on a 1.5V regulator?
                        However, the regulars know all too well that at least once a week, we get led on a wild goose chase due to batteries on the multimeter being weak/bad, but there is no "low battery" indication on the multimeter lcd screen.
                        --- begin sig file ---
                        --- end sig file ---
                          A possibility is whatever is feeding those three regulators is excessively noisy or oscillating. This would also cause the video noise issue.
                            That can be bad filter caps before and after the LDO and cause Osc like TOM said.
                            It will be easy to parallel another cap at pin 2 of the LDO to find out.
                            • gijoey198079
                              • Dec 2012
                              • 53
                              I changed batteries in the multimeter but readings were only .01-.04 difference in the first time, i ended up just using the spare board i had here and already got it sold.
                              Thanks all for the help.
                              • SS454
                                vizio e650i-a2 backlight flashes then turns off
                                by SS454
                                vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                panel: au optronics T650HVN05.4
                                72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                08-20-2020, 03:57 PM
                              • mrtek
                                Vizio M65-C1
                                by mrtek
                                Hi.
                                picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                07-14-2025, 07:28 PM
                              • howardc64
                                Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                by howardc64
                                Failure Symptom
                                No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                Where is the short?
                                Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                05-27-2025, 02:56 PM
                              • howardc64
                                Vizio SmartCast TV software bug that looks like hardware
                                by howardc64
                                Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                11-16-2024, 05:17 PM
